headlight switch control knob
Old Jan 21, 2010 | 12:48 PM
gglow's Avatar
headlight switch control ****
trying to install control shaft into switch seemed simple enough, however
in will not lock into place. what am i doing wrong? car is '70 442.
Old Feb 21, 2010 | 02:16 PM
Jaybird's Avatar
There is a little button on the back of the switch. Push the button and the **** and the shaft should click into place.
I hope this helps.
Old Feb 21, 2010 | 03:07 PM
I hope this helps.
Ditto, if the button is not on the back, some of them are on the top. You'll feel it really easy and its spring loaded. So if you need to take the light pull out, you hold the button down while pulling. Suggest you have the power lead disconnected though or your lights will be on for a loooooonnnng time before the go out.
Old Feb 21, 2010 | 03:54 PM
bigoldscruiser's Avatar
2 '66 98's
Sometimes they are a little tricky. Start the shaft in the switch and then give it a quick rap to help seat it in place.
Old Feb 22, 2010 | 12:47 PM
gglow's Avatar
Thanks for the input. Pulled the switch out ,pushed the button a few times and reinstalled it. It works fine now,maybe the button was stuck open. Once again, thanks for the input.
junior supercar
Nov 25, 2014 12:51 PM
techcote
Mar 10, 2013 07:58 PM
Tedd Thompson
Jan 20, 2013 04:00 PM
Benton Quest
Jan 3, 2013 09:30 AM
