49 radio needs a replacement
Old Mar 24, 2010 | 03:48 PM
oldbill's Avatar
Radio in my 49 last played a tune 3 years ago... I would love to find some one to fix it but if that fails I would like to convert to something that still looks like the original.. I saw a radio replaced by an MP3 but I don't really want that. AM only would be fine. Just show me the Music..
Old Mar 24, 2010 | 05:34 PM
jaunty75's Avatar
I'm guessing it has tubes? Have you tried replacing any of them? They're actually surprisingly easy to get and not usually all that expensive.
You would need a tube tester to actually test the tubes, but it's probably just as well to replace them all.
Here's a couple of possibilities:
http://akronantiqueaudio.net/splash.asp
http://www.tubesandmore.com/
I've had dealings with the second one in the past, and they were fine.
Make a list of the tubes you need with each one's number (12AX7 and like that) and then get on these websites or call them up and see what they have.
Old Mar 25, 2010 | 03:28 AM
oldbill's Avatar
Old Radio Tunes
Thanks, I'll give them a try. I had been told by locals that none of that stuff was available. I took the radio out and took the bottom off and the tubes are all right there where I can see them and read the numbers. I would be nice to keep it original.
Old Mar 25, 2010 | 03:38 AM
jaunty75's Avatar
Darn those locals!
Keep in mind that it may not be just the tubes or even the tubes at all. I've brought back to life a few old radios over the years, and while new tubes do the job most of the time, it's also possible that new capacitors or other components are needed. But it certainly should be possible to return your radio to working condition as is as opposed to replacing its internals with modern circuitry.
Old Mar 25, 2010 | 04:33 AM
Oldsguy's Avatar
Past Administrator
Another problem may be the old paper style capacitors, they just don't hold up over time and their values have changed so much that the radio may work, but very poorly. There are places that will repair your radio to like new condition, or upgrade it whichever you wish. I will see if I can find the link to one of them.
Here is one of them.
Old Mar 25, 2010 | 04:41 AM
Oldsguy's Avatar
Past Administrator
By the way, I think I missed your previous posts and never welcomed you to the site. It is kind of late but welcome to the site. Ever get your other projects finished (brakes, suspension)?
Old Mar 26, 2010 | 03:48 AM
oldbill's Avatar
I looked at the Bobs Radio site and I noticed that he will NOT guarantee any radio on an 8V system! I am running an 8Volt battery in my 49. Its about the only way to be sure it will start! I just wonder what damage that will/has caused to the radio? It seems to me that some kind of a stepdown transformer could cut the 8V back to 6V if it really damages the radio?
Old Mar 26, 2010 | 04:02 AM
Destructor's Avatar
Keep the tube radio and have it rebuilt, replacing caps and out of spec resistors. It's a novelty.
CyberCholo
Jun 6, 2015 04:20 PM
Mark57
Apr 19, 2014 05:12 AM
HLS
Feb 21, 2014 06:30 PM
HLS
Feb 17, 2014 07:51 PM
68conv455
Nov 19, 2011 07:36 AM
