My horn won't stop beeping!
My last post was resolved with the simple swapping of the fusible link. Now hopefully the last electric gremlin I have is why my horn blows when I turn the wheel side to side. I replaced the stock wheel with a cheap Grant one, with the recommended installation kit....with the wire with the little brass plunger at the end that you lock into the spring. I tried compressing/stretching the horn button spring thinking it may have been contacting prematurely. I also thought that the horn wire in the steering column may have a knick in it thats grounding out. Any ideas??
Something else
Ok after messing around with it today. I found that if I pull out on the wheel, then turn it, it is ok, but if i push the wheel back in, it blows again. It is a barely noticeable amount of play, but it seems to be enough to be the difference between grounding and not. Did I maybe have the wheeled installed too far in on the steering shaft? Maybe pushing the metal adapter too close to either the wheel or steering column? Anyone? Help?!?
Oh, almost forgot. The Grant wheel had way smaller diameter and made seeing the gages a PITA. Another reason I hated it.
