headlight problem
I've had this problem before, and unfortunately it can be almost any of the connections between the alternator and the lights. Certainly check the grounds, but check everything else, too. In my case, it was a corroded terminal at the junction block on the horn relay. The resistance caused low voltage whenever the current draw was high (ie, when the headlights and brake lights were on at the same time).
