67 Delmont headlight problem???
Old Jul 16, 2011 | 03:08 PM
victorMhernandez's Avatar
425Delmont
I have a 67 delmont, my turn signal lights turn on but wont flash.
I replaced the flasher in the fuse box and nothing hapenned.
I thought maybe it was the turn signal switch so i replaced it but still no flash.
Anyone have an idea of what it might be?
Old Jul 16, 2011 | 04:54 PM
Beob's Avatar
My car has two flashers, one on fuse box and one under dash. Check under dash to the left of the column. I think the one on fusebox is for hazzards
Old Jul 16, 2011 | 05:12 PM
jaunty75's Avatar
Yes, the one on the fusebox is for the four-way flashers activated by the button on the steering column. There is a separate flasher under the dash that controls the turn signals.
Also, the turn signals will not flash on one side (left or right) if there is a burned out bulb anywhere on that side (taillight or front turn signal light). If the turns signals don't work on either side, you could have a burned out bulb on each side. Make sure all the bulbs are good.
Old Jul 26, 2011 | 05:52 PM
425Delmont
Ive tried looking for the flasher behind the dashboard but havent been able to find it .
Im gonna check the bulbs like you said. Thanks for the help!
Old Jul 26, 2011 | 06:04 PM
Oldsmaniac's Avatar
Since you cannot find it it may be missing...look harder or look for plug under dash that it plugs into.
Old Jul 26, 2011 | 06:21 PM
425Delmont
Does anyone have a picture of where its located on a delmont?
Old Jul 26, 2011 | 07:19 PM
Jaybird's Avatar
Could it be possible that one of your bulbs is burnt out?
Jaybird
Old Jul 26, 2011 | 07:21 PM
The location is not given in the Chassis Service Manual. It should be in your Owner's Manual. It's usually clipped (or hanging) up under the dash, probably to the left of the steering wheel.
patmills
Dec 6, 2010 06:01 AM
olds67
Nov 8, 2010 12:23 PM
Fitzgerald
Jul 17, 2010 09:29 PM
denf221
Jan 16, 2010 06:02 PM
sickbox
Nov 20, 2007 03:56 AM
