Distributor Cap
Old Apr 10, 2010 | 09:42 AM
Gary's 2 442-S's Avatar
Gary
Distributor Cap
Can anyone tell me where is the #1 plug is located on the distributor cap on a 72 455 is. I am putting back the spark plugs and forgot to mark the cap. I am thinking that it is the first port just left of the point adjustment opening window. I know what the firing order is.
Old Apr 10, 2010 | 10:16 AM
svnt442's Avatar
It should be pointing at #1 spark plug.
Old Apr 10, 2010 | 11:08 AM
henryk8398's Avatar
Hangin' out...
I don't know what the factory stock location for #1 is, so I would suggest you pull the #1 plug out and crank it over to TDC. That's the only sure-fire way to find it. What I usually do is put a small wad of paper towel in the spark plug hole. Bump the starter a few times. When the paper shoots out, you should be at TDC. You should even be able to see a very small part of the piston through the spark plug hole. See where your rotor is pointing. That should be enough to get you going.
This is a bit more detailed:
http://wiki.answers.com/Q/How_do_you...on_a_350_chevy
Old Apr 11, 2010 | 02:19 AM
svnt442's Avatar
Well #1 on the cap is supposed to point at the #1 cylinder from the factory. But checking is a good way to be sure it is installed correctly.
Old Apr 11, 2010 | 06:39 AM
Bluevista's Avatar
Registered
Maybe...maybe not, all things are not as they're supposed to be, life ain't TV fix-it shows and how-to books.
One word, Oldchassisservicemanual.
You anti-CSM guys are way better than me, my heroes, I've been working on cars for over 40 years and I still have to look at the instructions.
Old Apr 11, 2010 | 10:18 AM
svnt442's Avatar
I have one of those. They are straight up bibles.
Blue71Cutlass
Sep 18, 2011 10:59 AM
bgoble
Nov 12, 2010 08:16 PM
amphicar770
Oct 31, 2010 05:38 PM
MX442
Oct 29, 2009 08:25 AM
