rpm gauge help
Old May 20, 2010 | 11:28 AM
mryoung4815's Avatar
Exclamation rpm gauge help
i have a 1972 cutlass s with a 1972 350 rocket with some extras and i am trying to put a sports comp auto meter rpm x1000 and im not sure how to hook it up i have the ground wire grounded and im not too conserd about the white illumination wire but im not sure where to the red and the green go i know that the green wire goes through the firewall and the red has to be connected to a power source that turns on when the car is on but im still not sure any body have any ideas?
Old May 20, 2010 | 11:40 AM
jeffreyalman's Avatar
not sure of your model but I would think there is an installation sheet?
If not, looks like they have down-loadable material here
Old May 20, 2010 | 05:50 PM
svnt442's Avatar
The green wire goes to the - on the coil. The red can be hooked to the accy port in the fuse box.
Old May 20, 2010 | 07:15 PM
You'll care about the white wire if you ever drive at night.
Red = key-on +12V power
Black = ground
Green = neg (distributor) side of coil or TACH terminal on HEI
White = inst panel light feed (grey wire under the dash)
JPMDaddy
Jan 31, 2020 04:01 AM
Del70
Aug 23, 2017 03:59 AM
Fear Reborn
Nov 30, 2011 03:50 PM
trez
Mar 23, 2011 12:20 PM
rick_roach
Nov 3, 2008 03:57 PM
