Help! My '65 Cutlass is Smoking
Old Mar 31, 2010 | 07:02 PM
Snowdog's Avatar
Unhappy Help! My '65 Cutlass is Smoking
I stored my '65 Olds Cutlass in the fall with the Irish Spring to prevent mice and it was running fine before I closed it down for the season.
Today, I took off the cover and hooked everything back up. When I hooked up the battery, I heard a snap. I went to grab a wrench to tighten it down and then, I turned around and saw that it was smoking from the alternator. The wires are fried all the way to the firewall, but not to the coil. I know I need a new wire harness. Any ideas would be helpful. Thank you!
Kevin
Old Mar 31, 2010 | 07:06 PM
442scotty's Avatar
If they are fried to the firewall the fuse box and dash wiring may be done as well...at least you didnt have a fire...The good news is that all the correct harnesses are available from M&H or Ron Francis...the bad news is its gonna cost you a few bucks...about 600 for the front harnesses and a new dash harness using your fuse box..
Old Mar 31, 2010 | 08:21 PM
Snowdog's Avatar
Any Idea what could have caused this,
besides being 45 years old?
Only 46,000 original miles on her
Old Mar 31, 2010 | 08:22 PM
2blu442's Avatar
Ouch! have you identified the location of the short?
Old Mar 31, 2010 | 08:24 PM
2blu442's Avatar
I'm lousy with electrical stuff. But it seems like you must have a short somewhere. Can you trace out all the burned wires? John
Old Mar 31, 2010 | 08:26 PM
Snowdog's Avatar
Not yet can't work on her now
I'm in the moving process outa
Willow Springs
Old Apr 1, 2010 | 07:17 PM
Snowdog's Avatar
Talked to Fusicks and they want $166 for a wire harness. Talked to some old timers today and they said, "just disconnect the alternator." Did that and the car started right up. Now I will just get a new alternator and replace the bad burned wires. All lights work except fuel guage.
Old Apr 1, 2010 | 07:48 PM
2blu442's Avatar
So you think the short was inside the alternator? It would be good to identify what shorted out before driving it. John
Old Apr 2, 2010 | 07:43 AM
442scotty's Avatar
Glad to hear it turned out not too bad ...replace the regulator too if you have one...Its a good time to check all of your wiring inside and out...look for cracked wires and burnt ones that are still working...wiper switches are bad for that
dgreen
Jun 27, 2010 08:25 PM
Gaz Hog
Mar 22, 2009 03:39 PM
Vincent Woodard
Oct 18, 2008 01:21 PM
Redog
Mar 11, 2008 10:37 AM
dynamic88
Jun 3, 2007 01:00 PM
