Air conditioning. Fast idle solenoid
Old May 10, 2021 | 11:28 AM
7314haywood's Avatar
Trying to find one to increase idle when air is turned on. The original one is broke at the connection. Definitely need one as when in park it idles to fast and has run on. Tried Oreillys as they had my tail light sockets but no luck on solenoid. Any ideas?
Old May 10, 2021 | 12:20 PM
I recurved the distributor so initial is around 18º and after that the idle doesn't drop when turning the AC on.
Just a thought for you.
Old May 10, 2021 | 12:21 PM
Disregard. I reread performance ignition and I raised timing when rpms drop with air turned on. This distributor really has nice feature including theft deterrent
Old May 10, 2021 | 12:54 PM
Idle
Thanks that's what I did. I'm at 14 degrees in gear no air. Turn on and the rpm does drop and I put timing at 18 degrees. I can run 87 octane in Az heat without pinging
Old May 10, 2021 | 02:11 PM
cdrod's Avatar
Rodney
Haywood:
I have a fast idle solenoid (I think for a Q-Jet) if you find that you still need the extra RPM bump.
Rodney
Old May 10, 2021 | 03:42 PM
Originally Posted by cdrod
Haywood:
Rodney
If you find it have an idea on the price and you can test it I would still be interested in it
chenner
Mar 30, 2020 06:20 AM
EightballZ
Aug 26, 2015 11:02 PM
AZ455
Aug 2, 2011 09:19 AM
roomer
Jul 11, 2011 06:36 AM
84oldsDelta88
Dec 11, 2009 06:19 AM
