1964 Olds Cutlass 330 4v clock removal
Old Nov 17, 2020 | 08:15 AM
alsmith787's Avatar
Good Morning Guys
Need some help & advise (call it guidence) I need to remove the clock for repair on my 64 cutlass 40 yrs ago I was thinner & agile, even think my hands were smaller lol
Is there a Sane way of removing it so you don't break some other wiring etc from underneath the only way I can see is dash top pad but that might be worse especially since none of these have ever been touched since the factory
Any suggestions would be greatly appreciated
Old Nov 17, 2020 | 10:15 AM
jaunty75's Avatar
The clock and everything else on the dash on these cars is accessed from under the dash. If you lie on the floor and look up, you'll see everything.
And, no, we don't need to know what engine and carburetor are in the car in order to remove the clock. But knowing the car's color would help.
Old Nov 17, 2020 | 10:27 AM
Yeah, as a lifelong smartass I was wondering if the procedure was different for cars with the 2 BBL engines.
If you gotta lay on the floor and reach up behind the dash, it may be easier if the seat is removed. I had to do that the last time I replaced the heater core; never needed to in the past 40 years but it was worth the extra effort this time.
Old Nov 17, 2020 | 10:33 AM
rocketraider's Avatar
Oldsdruid
Not sure on Cutlass and don't have my 64 CSMs handy, but on the big cars removing the glove box door and liner offers access to the clock. Might have to remove an AC manifold if equipped.
Look at it this way. Clocks were often dealer installed so working flat rate, factory wasn't gonna make that installation overly complex. Not in those days anyway.
Old Nov 17, 2020 | 11:19 AM
jaunty75's Avatar
This is the entirety of the clock removal and installation section from the 1964 Olds Chassis Service Manual for the 30, 31, and 32 series cars (A-bodies).
Removing the glovebox will be of no help because the glovebox is way over on the right side while the clock is just left of center.
As I said, the only way to get at the clock is up from underneath.
gkhashem
Ninety-Eight
May 18, 2017 02:43 PM
jerrybetty5
Feb 4, 2016 12:56 PM
Hairy Olds
Dec 11, 2014 02:06 PM
Eubiedad
Apr 30, 2014 03:40 PM
70 ctls
Nov 12, 2013 08:07 AM
