Missing P/E brake switch
Old Jan 3, 2021 | 04:33 PM
CuttyShark's Avatar
Pretty sure I am missing a switch here at end of this brown and white stripe wire. Cant locate the switch online that looks to fit this bullet end of the wire. What am I looking for?
Old Jan 3, 2021 | 04:42 PM
I found this on the net. It says for 70-72 Cutlass but I can't verify it is correct.
https://claz.org/go?url=http%3A%2F%2...ly-i1474359%2F
Old Jan 3, 2021 | 06:43 PM
That is what the switch looks like. It's just a pin switch like the ones used on door jambs for the dome light.
Old Jan 3, 2021 | 07:15 PM
CuttyShark's Avatar
Ok that narrowed down search to this little guy that stock end of the wire does not look big enough to fit on end of this switch is there some trick to it?
Old Jan 3, 2021 | 07:19 PM
The bullet connector on the end of the wire pushes into the barrel on the switch.
Albscar442
May 17, 2020 11:35 AM
Zr1bandit
Oct 4, 2017 07:14 AM
Higgins
Nov 12, 2012 12:37 PM
805cut
Sep 2, 2012 11:02 PM
Redog
Apr 13, 2012 01:14 PM
