Under dash lamp short
Old Mar 22, 2021 | 06:05 PM
wherlehy's Avatar
OK experts - need help - and let me start off by saying how much I hate electrical wiring in these old cars.
1970 Cutlass S - Courtesy Lights
All my interior lights work (dome, gauges, map, console, rear view mirror, ect...) except for the passenger side under dash light. Any time I put a new bulb in it, the fuse blows. I purchased a new receptacle for the passenger side thinking the receptacle is bad. Nope, even after replacing the receptacle it still does the same thing - blows the fuse. So logic tells me I have to painstakingly trace the short from the receptible back. At 6-2, 235lbs no small feet to lay under the dash.
Any quick ideas that I am missing? The whole harness works except for this socket.
Thanks.
Old Mar 22, 2021 | 09:01 PM
I moved your post to its own thread, there is no reason to resurrect an old unrelated one with your question. If the fuse does not blow without the lamp your wiring is good and it's related to the socket area.
Old Mar 22, 2021 | 09:52 PM
Sugar Bear's Avatar
Can the sockets be swapped side-to-side? If yes, do it and see if the problem follows the socket vs. stays with the circuit.
Good luck!!!
Old Mar 23, 2021 | 05:58 AM
Schne442's Avatar
No it's not a parts car!!
Make sure you are using the correct bulb
cant remember for sure but I think it is a two contact socket if you use a single contact bulb you will short the circuit and blow the fuse
Old Mar 23, 2021 | 06:22 AM
wherlehy's Avatar
Yes, the original wiring has a two lead socket and the bulb is a single lead. Makes sense what you are saying. Now I just have to find a two lead bulb for the socket.
Thanks!
Old Mar 23, 2021 | 06:33 AM
Schne442's Avatar
Thanks!
I made the same mistake on my 72 convertible found out that the two under dash and rear armrest courtesy bulbs are the same two pin sockets
once I actually stuck my head under to look I found out what the problem was. DUH!!
Old Mar 23, 2021 | 07:11 AM
Sugar Bear's Avatar
Good call...the wrong bulb base will blow the fuse for certain. I never thought of it.
Old Mar 23, 2021 | 07:17 AM
wherlehy's Avatar
How do you think I feel, I am an engineer that work on Military Défense for years and 5G telecom... I feel like a dope. I will just call it a senior moment.
Old Mar 23, 2021 | 08:08 AM
Schne442's Avatar
Don't feel too bad, my list of screw ups and mistakes working on my car is long and embarrassing also and I am a chief Engineer working for a large state Public office
just go back to the basics when troubleshooting these type of issues.
one time 20 plus years ago I arrived at work to find the Day shift Engineer on a ladder digging in an Electrical circuit box on the Boiler room ceiling
He had every cover of every 1900 box off, I asked him what he was doing, He said the Boiler room doorbell isn't working. I asked him if he checked the Doorbell and he said "no, I started tracing out the circuit and haven't gotten that far yet" I grabbed a screwdriver and removed the Doorbell button and found the spring inside had popped off and was preventing the contacts from making.
I reset it put the button back up and tested it. after 5 minutes of work I fixed it. the more experienced Engineer had spent the better part his shift trying to figure it out.
I told him "I guess you started at the wrong end"
Old Mar 23, 2021 | 08:12 AM
Sugar Bear's Avatar
My list of screw-ups earned me a "been there done that" t-shirt. The t-shirt has gradually morphed into an elaborate wardrobe!!!
Old Mar 23, 2021 | 04:16 PM
wherlehy's Avatar
OK my friends I need help again. After putting the socket back into under the dash mounting panel the two leads in the sockets (no bulb, had to order one) touched and sparked and now I have NO electrical. The courtesy light fuse blew but in the past the car would still start and work fine without this fuse. I tried jumping it and I would only receive enough juice to hear the key buzzer - nothing else worked. No headlights, starter won't crank, no gauge warnings during the start mode.
Did the battery blow or did I fry another fuse outside of the fuse box? I should of stayed with the "if it ain't broken don't fix it..."
Old Mar 23, 2021 | 06:14 PM
rocketraider's Avatar
Oldsdruid
1) do you have the factory shop book with the color wiring diagrams? If not, get it.
2) I think it would be unusual, but you have possibly burned out a fuse link. Look at the junction block on the fenderwell.
3) always a good idea to either disconnect battery or remove the courtesy lamp fuse when fooling with constant 12v powered components.
Old Mar 23, 2021 | 08:53 PM
If you have no power to the cabin, you probably fried the fusible link wire (red) that feeds from the horn relay to the bulkhead connector.
Old Mar 24, 2021 | 07:15 AM
Schne442's Avatar
Incase you don't have it, This for a 72 but should be the same for 70 for the area of concern, If not someone will correct me
Bobac455
May 1, 2021 12:06 PM
hookem horns
Nov 6, 2011 06:45 PM
Bryan59EC
Jun 13, 2010 08:27 AM
Scottem
Sep 28, 2009 10:23 AM
Jaked
Sep 3, 2004 04:45 AM
