1970 Cutlass starting issues
Old Jun 15, 2021 | 05:03 PM
rktlnchr's Avatar
I recently purchased a ‘70 cutlass post coupe that sat for a few years. It was started every few months to move it. It would start fine until I brought it home. Starter solenoid would click but not turn over. I figured something was draining the battery so I reinstalled the door jamb switches for the dome light. Dome light came on & a few courtesy lights under the dash. Later I went to start car & battery was dead. No gauge lights at all. Charged battery & battery light domes on but no solenoid noise or dome light. Any suggestions?
Old Jun 15, 2021 | 05:17 PM
Sugar Bear's Avatar
Try jumping it with another car. Look for loose/dirty connections at the battery. Do the headlights work? If yes leave them on and turn the key to crank. Do the headlights change, go dim, go out?
​​​​​Good luck!!!
Old Jun 16, 2021 | 04:11 PM
PatL's Avatar
sounds like the battery may be bad. Also if you get it running, check the voltage across the battery.
Old Jun 19, 2021 | 12:07 PM
rktlnchr's Avatar
Update. Replaced both battery terminals as I noticed positive cable looked corroded & I had 12.7 volts at the battery so I figured it wasn’t getting good contact.
Old Jun 19, 2021 | 01:58 PM
That will do it. A small amount of corrosion will cause a no start and charging issues.
lmarquette
21
Jul 24, 2021 02:03 PM
MidNight Rider
Alero
Nov 28, 2018 02:38 AM
tnelson
Sep 10, 2010 05:42 AM
Southern_Hospitality
Sep 30, 2009 02:00 PM
branemi
Jul 20, 2007 09:46 PM
