car wont start. no dummy light, radio, anything
ok guys, i parked my 77 grand grix(factory olds 350 rocket) outside for the weekend came out two days later and it wont start. when i tried to jump it the dash lights turned on only with the cables on but i wouldnt turn over. i heard a clicking and assumed it could be a starter. well im stupid and put it in for nothing. i dont wanna make another dumb move so please help, bad battery?, alternator?, fuse?, wiring?
Clean the battery connections. Your solenoid is clicking from lack of battery power. Did you leave a light on over night? If so your battery is really dead and will need a good charge. Leave it on a 15 amp or more charger for a hour or two and try it again. You may have lost a cell in your battery and it could need replacing. A battery from another car will start it faster if you need to get on the road. Are you in the Twin city area?
Try to charge overnight. If unsuccessful, the battery is prolly gone.
Good idea also. They check initial voltage, load test it and check the recovery rate. Fast and accurate.
Arrowstorm
August 9th, 2015 04:27 AM
