1974 cutlass wiring connector missing!
Old Jul 8, 2021 | 04:13 PM
tay2x's Avatar
SOS. Bought a ‘74 cutlass few days ago and looks like
it’s missing a couple connectors (front body connector and maybe another one. The tail lights and from park lights work but the brake lights don’t, the horn, turn signals or horn work. I was messing around with the wires to see which one was hot and jumped the turn signals. Is there a wiring diagram I can follow also is there a way I can wire these back up without buying a whole new harness because I can’t find just the connectors alone. If someone know where I can get just the connectors can you link them? Also a picture of yours would be nice to compare side by side or a picture of the diagram
Old Jul 9, 2021 | 08:03 AM
RetroRanger's Avatar
72 Olds CS
Welcome to classicolds. IDK what that type of connecter is called but you might find some on ebay or here is an unsealed connector kit on jegs https://www.jegs.com/i/JEGS/555/10900/10002/-1 that might be similar. A chassis srvice manual AKA CSM for your model year is a good start for a wiring diagram and a great tool to help you along the way. The original print manuals generally have clearer images VS reproductions.
Old Jul 9, 2021 | 08:34 AM
rocketraider's Avatar
Oldsdruid
Hully jayzus why would someone do something like that?
X2 on an original PRINTED COPY 1974 Olds factory Chassis Service Manual. It will have the color wiring diagrams as well as drawings of how all the stuff is routed and mounted in the car.
See if anyone here is parting a 74 Cutlass and is willing to sell the connector or harness you need. I'm thinking it's gonna be 74 only but can come from any Cutlass series car.
The Packard brass terminals aren't hard to find, if you end up repairing what's there.
Lawdy. I expect things like that on a Chevrolet but that's one of the biggest wiring messes I've ever seen on an Oldsmobile. Good luck.
Old Jul 9, 2021 | 08:43 AM
Oldsdruid
Also- if you decide to keep the aftermarket gages ditch that plastic oil pressure gage tube and use copper line with a vibration loop on engine side before it goes thru the firewall. Might keep from coating yer toes with hot oil.
Old Jul 10, 2021 | 04:02 AM
gear head's Avatar
I have had good luck finding connectors and pins at Newark and TE...
https://www.newark.com/c/connectors
https://www.te.com/usa-en/store.html
Old Jul 10, 2021 | 05:23 AM
Bill G's Avatar
Wiring diagram
Welcome.. good luck with your 74..I've had fun with mine over the years..
hopefully the pic of wiring diagram comes through ok..not sure I can get decent pic of harness.
lots of knowledge here..
Old Jul 10, 2021 | 05:26 AM
Bill G's Avatar
oops..sorry about the upside down..not great with my cellphone camera..
Old Jul 10, 2021 | 05:34 AM
ignachuck's Avatar
Frank Ignachuck
I flipped it and cropped it.
Old Jul 10, 2021 | 01:30 PM
Bill G's Avatar
Danke
Danke!
LAolds
Aug 19, 2013 11:33 AM
Beob
May 16, 2011 06:43 PM
TripDeuces
Jul 22, 2010 10:54 AM
mauls
Jun 8, 2010 03:43 PM
Calvin.Norris
Nov 27, 2007 06:08 PM
