Rear Lights not Working
Old Nov 26, 2007 | 04:09 PM
Calvin.Norris's Avatar
Question Rear Lights not Working
My rear lights will not work the running ones or the brake lights turn signals etc. but my front lights work turn signal and all but when I change the rear fuse it continue to blow. What should I do to fix.
Old Nov 26, 2007 | 04:13 PM
dallas6778's Avatar
sounds like a wiring problem. my cutlass had same problems until i got under the steering column and fixed up some worn wires in the large wiring harness under there. if it is the fuses, you may have a crossover or some other kind short somewhere.
Old Nov 26, 2007 | 04:54 PM
ozoneblue's Avatar
Start by unpluging the rear harness in trunk area LH side replace fuse ,If it dosen't blow then start checking all rear bulbs & sockets.If you have any trailer wiring disconnect it Ps you diddn't say type & year Olds
Old Nov 27, 2007 | 04:17 AM
Jim's rare 80's Avatar
Jim's rare 80
Also check the ground wire in the trunk. It will be at the left hand side, near the left tailight. Usually under the carpet. Let us know what you find.
Old Nov 27, 2007 | 06:08 PM
Modern Motoring's Avatar
must be the season.. my 63 just lost the brake lights... worked fine the oter day, now nothing. Power is at the fuse, thru the fuse, but nothing at the switch. OY!
nelsontj
May 19, 2009 09:32 PM
cbogartjr
Aug 3, 2008 06:18 AM
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
<KEN>
Sep 22, 2004 08:39 PM
