Lights Not Working
Old May 19, 2009 | 02:50 PM
nelsontj's Avatar
Lights Not Working
On a 1970 Cutlass/442 the courtesy, map and mirror lights are not working. All of the other lights work. I checked the bulbs and fuses and they tested was working. Help!!!!
Old May 19, 2009 | 03:08 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Take a look at the taillights. If memory serves me correctly (does not always happen at my age), I think the dash lights are on the same fuse as the taillights. Check the fuse and I bet you will be okay.
Old May 19, 2009 | 04:01 PM
Texascarnut's Avatar
Geezer
You have a broken wire, bad connection, or relay problem between the fuse box and battery power. That circuit does not go through the headlight switch or the ignition switch, though it may jumper off of the headlight switch connector.
Old May 19, 2009 | 04:27 PM
nelsontj's Avatar
Thanks for the help! I dug in and found it was a harness that came disconnected behind where the clock/tach goes. It must have come apart when I put the radio back in after I had taken it out to replace a bulb.
Old May 19, 2009 | 09:32 PM
redoldsman's Avatar
Glad you got it fixed. After I read the post again, I notice you did not ask about dash lights. Somebody on here usually gives the correct advice.
cbogartjr
Aug 3, 2008 06:18 AM
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
