Headlamp with DRL light
Hi have someone mount this headlamp to your Olds ?
Narva | Search
In Sweden we need to have lights on even on a bright day 24/7
Would be
nice with headlamps with drl light . Not sure if the light above will fit into
headlamp housing Olds 88 / 98 -65 ?
Narva | Search
Would benice with headlamps with drl light . Not sure if the light above will fit into
I had the same idea as Joe and used a DRL conversion module. I got mine from https://dastern.torque.net/Mods/DRL/DRL1.html
It uses the bright filament in the turn signal as the DRL. It works well and doesn't require surgery (except to wiring).
