Headlamp with DRL light
Old Jul 22, 2021 | 06:07 AM
GCH's Avatar
GCH
Hi have someone mount this headlamp to your Olds ?
Narva | Search
In Sweden we need to have lights on even on a bright day 24/7 Would be
nice with headlamps with drl light . Not sure if the light above will fit into
headlamp housing Olds 88 / 98 -65 ?
Old Jul 22, 2021 | 08:29 AM
You'll probably have to perform some surgery to the headlight bucket for them to sit flush.
Old Jul 22, 2021 | 10:04 AM
There are a lot of DRL conversion modules that just use the existing lamps.
Old Jul 22, 2021 | 01:24 PM
GCH's Avatar
GCH
Thanks for tip , should look at modules also.
Don't want to do any surguary to the cars
headlamp buckets.
Old Jul 22, 2021 | 07:45 PM
VC455's Avatar
Barely Registered
I had the same idea as Joe and used a DRL conversion module. I got mine from https://dastern.torque.net/Mods/DRL/DRL1.html
It uses the bright filament in the turn signal as the DRL. It works well and doesn't require surgery (except to wiring).
Old Jul 23, 2021 | 10:30 PM
GCH's Avatar
GCH
Thanks for tip Gary , should check that link
therobski
Aug 5, 2018 11:10 AM
therobski
Aug 3, 2018 01:09 PM
scott_442
Jun 13, 2012 07:21 AM
marcocutty82
Sep 4, 2011 11:36 PM
68ragtop
Dec 16, 2010 05:37 AM
