Distributor Shimming
Old Feb 12, 2021 | 10:34 AM
Okie Rocket's Avatar
Can someone answer a question for me about "shimming" the Distributor on a 1970 442? In the factory Oldsmobile Parts & Illustration Catalog, it shows there should be a "Washer" installed between the bottom face of the Aluminum Distributor Housing and the top of the Drive Gear.......however...... in many photos I have seen, it looks like there is no Washer installed in this area. I'm sure some have chosen to possibly "leave out" the Washer, when re-installing the Gear, but some of the Used Distributors I've seen (i.e., that appear to possibly be original) don't look like they have a Washer installed on them?? Any idea which is correct???
Old Feb 12, 2021 | 03:20 PM
VC455's Avatar
Barely Registered
I have three 1970 distributors, two from a 442. None has ever been disassembled. None has the washer (#23 on your BOM).
In the 1970 CSM, page 12-40, is a disassembled distributor diagram. There is no washer shown.
Old Feb 12, 2021 | 03:29 PM
Thanks for the info. Gary.
Old Feb 12, 2021 | 03:50 PM
59-59-59's Avatar
You noticed a tiny washer in the picture, but not the oil tube (part #30) sticking out if the side?? That tube is for pre ‘60 or ‘61 engines
Old Feb 12, 2021 | 04:14 PM
Since it was a factory Olds Parts Manual I figured the picture was basically generic.......i.e., as it fit many "different" years.....
JOHNNYOLDS442
Jul 5, 2020 07:28 AM
Fpcopo
Jun 13, 2020 08:49 PM
Threejdsolds
Mar 8, 2020 06:30 AM
BillK
Feb 12, 2018 05:36 PM
4-ever-olds
Oct 3, 2009 08:51 PM
