Replacing wiring harness
Old Apr 3, 2021 | 04:31 PM
williamwallace11's Avatar
Hello all,
Just looking at my chilton book wiring diagram and all over the engine bay looking for this connector, does anyone know what it is at first glance. I致e been stumped for a few hours on this.
Old Apr 3, 2021 | 04:48 PM
nicks1966's Avatar
it goes to the ignition coil
Old Apr 3, 2021 | 04:51 PM
Okay that makes more sense. If I have converted to High Energy Ignition I知 assuming I知 going to have to alter this connection since its going into a modern style ignition system then.
Old Apr 3, 2021 | 04:59 PM
nicks1966's Avatar
the cloth covered wire is a resistance wire and does not supply a full 12 volts , the yellow wire is supplies a full 12 volts while cranking the car.
so depending on what you converted to you most likely will need to find a 12 volt source.
Old Apr 3, 2021 | 07:13 PM
Define modern style ignition system. The 2 wires (resistance wire - tan cloth and the resistance wire bypass - yellow from the solenoid) as stated above are the stock points coil+ terminal connections.
Old May 2, 2021 | 04:38 PM
cfair's Avatar
If you’re using and HEI electronic ignition, get rid of that resistance wire in favor of a thicker wire (10 gauge maybe) that will supply 12 volts to the HEI unit.
Cutlass Fan
May 2, 2021 04:42 PM
oldsmoboogie
Mar 12, 2021 02:55 PM
Boilerz25
Aug 6, 2019 07:20 AM
Rvsmith5
Feb 2, 2019 09:03 AM
pcard
Apr 10, 2014 08:55 PM
