Starter wiring 1971 Cutlass
Old Jul 30, 2021 | 09:45 AM
riskyb's Avatar
My starter has one larger post and two small posts. Going to a mini starter with one large and one small post. Question, what do I do with the the two small wires one is white and one is black? Thanks
Old Jul 30, 2021 | 09:52 AM
66SportCoupe's Avatar
Do you have any type of electronic ignition in it? If you do only run the purple wire to small post on starter. The other isn't needed. If you still have a points style ignition I don't have an answer to give you then.
Old Jul 30, 2021 | 09:57 AM
riskyb's Avatar
Was points car , then someone put a HEI in it.
Old Jul 30, 2021 | 10:02 AM
You don't need the wire that bypasses the resistance wire that is currently connected to the R terminal.
Old Jul 30, 2021 | 10:20 AM
You're good to go then. The purple start wire should also be larger than the run wire.
Old Jul 30, 2021 | 02:07 PM
PatL's Avatar
I put a mini starter in and have points on a 1971. I had to abandoned the bypass wire with the mini starter. Car starts fine through the resistance wire (granted in a garage during mild temps).
driskdg1#
Jul 12, 2021 01:56 PM
doctoroldsw30
Jun 14, 2019 12:55 PM
gtaa9
Jul 16, 2015 11:24 AM
scooter123
Apr 29, 2013 05:40 AM
88hurstolds
Jan 11, 2013 07:43 AM
