Heater fan motor works, car turned off
Old Jun 7, 2021 | 12:40 PM
EdwardB's Avatar
I followed the wiring diagram for the dash harness from the "72 Cutlass/442 assembly manual and I find that my fan switch on the heater controls turns the fan on and off whether or not the key is even in the car. Not a big deal but I believe the open circuit slowly drains my battery. I removed the fuse in the heater/AC spot on the fusebox and the fan is still able to be turned off and on by the fan speed control switch. Anybody have any thoughts on where I may have made a mistake? I've seen some videos on how to find a battery draw by disconnecting the hot on the battery and placing a multimeter into the line feed but the videos suggest pulling each fuse until you identify the draw. Not sure that would work in this case.
Old Jun 7, 2021 | 04:38 PM
Does this car have heat only or does it also have AC? The wiring and controls are a bit different between the two.
Old Jun 7, 2021 | 06:03 PM
EdwardB's Avatar
Hello again Ken, heat only. A suggestion was to replace the blower relay so I ordered one today since it is an inexpensive part. Now I'm having quite a time trying to locate the relay on the car. Wondering if it's under the dash on top of the blower box/heater core? I remember plugging in some wires there but my assembly manual only shows a "resistor" listed on page 160 (1972 Cutlass/442 assembly Manual). I'll keep looking.
Old Jun 7, 2021 | 06:19 PM
EdwardB's Avatar
I just found a thread which said to look behind the power brake booster. Nothing there. Only things on my firewall are the horn relay and voltage regulator. I don't believe non ac cars had a relay at this point. Which brings me to the question of why would there be juice flowing through the dash harness with the key off? I thought the only constantly hot line was for the light on the rear view mirror which works as it should.
Old Jun 7, 2021 | 07:01 PM
PatL's Avatar
The horn relay should be on the driver wheelwell housing (by the fender). The blower relay does kind of look like the horn relay
Old Jun 7, 2021 | 07:10 PM
PatL's Avatar
Edward, follow up
Old Jun 8, 2021 | 06:09 AM
EdwardB's Avatar
Thanks Pat for that diagram. A picture lays it out perfectly. So here's a thought. I have an aftermarket radio which has a memory and an EFI control module with a memory function. Both of these have a small feed to the horn relay for constant juice to maintain the memories. Would the combination of these two be enough draw on the battery to create a battery voltage drop of about 0.5 volts over the course of a few days? I used to have a switch on the hot feed from the starter to the horn relay but I was afraid of a cabin fire hazard and the memories would get erased after I shut off power. (Without the car ever having A/C there must not be a relay or 30 amp fuse)
Old Jun 8, 2021 | 07:41 AM
Dynoking's Avatar
Try this previous post;
https://classicoldsmobile.com/forums...wiring-103721/
Old Jun 8, 2021 | 04:14 PM
PatL's Avatar
there is a hot feed on the fuse box
Old Jun 11, 2021 | 06:40 AM
Tedd Thompson's Avatar
IF mine I would turn off the key turn on the heater then go to the fuse box and one by one pull a fuse till the heater quits. Follow that wire till you find your problem.... Just me ...Tedd
Zr1bandit
Sep 28, 2017 06:51 AM
1968_Post
Dec 28, 2016 04:19 PM
5998DownUnder
Jun 9, 2014 09:35 AM
michael hilsabeck
Feb 16, 2011 04:07 AM
Matt15
Oct 5, 2008 11:26 PM
