Extra connector?🤔🤔
Old Nov 18, 2020 | 04:40 PM
72455's Avatar
1972 U code Supreme
Extra connector?🤔🤔
This is attached to the wiring harness for the power driver bucket seat on my '72 Supreme, but it wasn't connected to anything. Is it for an option I don't have?
Old Nov 18, 2020 | 05:53 PM
My first thought was a heated seat/warmer. I have no idea if it was even offered. The other notion was some other type 'function' to the seat. Your seat is a 4 way bucket seat correct? The seat moves UP/DOWN & FWD/BK I would suspect.
Of note is this thread (below).
Evidently there were two 1972 4 Way Bucket seats offered?
Type w/ 2 Cables = 4939203
Type w/ 3 Cables = 9625772
I'm assuming cables refer to wiring cable but I might be incorrect.
Are there any markings on the seat frame, etc. w/ the above identifying numbers?
https://classicoldsmobile.com/forums...-frame-117691/
Old Nov 18, 2020 | 06:37 PM
I'm guessing that's for the seat switch that operated the FASTEN SEATBELTS warning light. It was first required on cars built after Jan 1, 1972.
Old Nov 18, 2020 | 06:45 PM
mrolds69's Avatar
Yes, that makes sense what Joe said. 1972 was the first year for that on Olds, I think.
Old Nov 18, 2020 | 06:55 PM
Jan 1, 1972 on all cars per Federal law.
Old Nov 19, 2020 | 04:40 AM
Dave - Since a FASTEN SEATBELTS warning light is the most logical & likely usage, I suspect you'll find the other wire either running under the carpet somewhere or possibly leading into an area around the center console if you have a center console?
At any rate:
Fasten Seat Belts 1972 Cutlass 442 Hurst Olds
Seatbelt Buzzer Question (72 Cutlass)
FASTEN SEAT BELT warning light option
Old Nov 19, 2020 | 05:39 AM
72455's Avatar
1972 U code Supreme
I'll check it out...if it's the seat belt buzzer, it's staying disconnected.
Old Nov 19, 2020 | 02:09 PM
Yellowstatue's Avatar
I think 2 or 3 cables would be 'drive cables'.
Old Nov 19, 2020 | 02:25 PM
Yes, Sir - it may very well be drive cables.
Old Nov 19, 2020 | 03:49 PM
4Speedy's Avatar
Seat belt sensor good chance.
But wasn't that only on the passenger seat?
What about the really rare option?
The automatic seat release?
pfergy600
Jul 14, 2016 01:01 PM
cadillac kevin
Jan 22, 2014 10:30 PM
hajnovak
Hurst/Olds
Jan 31, 2013 10:24 AM
JimpeBoy
Aug 23, 2010 07:28 AM
Allan R
Jul 26, 2009 07:24 PM
