- 1947 horn button
- 55 Frustrations
- 1955 Oldsmobile Power Steering
- 1947 wiring diagram
- 303 Nightmare
- CA residents and S.B. 1239
- 55 Lap Robe cord
- Valve cover lettering
- 53 Brake Shoes
- Looking for trim clips
- 55 window insulation
- Looking for suspension bushings 47 olds
- 53 DS Lug Nut Removal
- 1955 Olds rear anti sway bar bushings
- rear end ratio
- 1948 model 66 fastback coupe tires
- 1950's manual transmission? Help identifying
- Looking for previous owner 1947series 66 coupe flat black
- '56 Heater Fan Resistor
- Rockerowner's new pictures
- Annoying Squeak in passenger rear suspension
- 1941 oldsmobile 98 "257 Flathead straight 8" burning oil
- Towing a small trailer with my 56
- One For The Money, Two For The Road
- Part number needed...
- Posi-traction in 55 Olds rearend
- Need help with vacuum lines on '56 Olds
- 55 Steering Wheel Horn Parts
- 53 Battery Hold Down
- 55 hood chrome lip molding
- 1930 Oldsmobile
- I should have stopped in...
- What headlight to use in my 47?
- Looking for a 54 ninety eight?
- 53 Carter Carb Flooding Video.
- prime the fuel pump? 55 Old's
- 55 headliner question
- Windshield Trim?
- 53 Heater Problem
- What is this? 55 Olds
- 55 heater hose routing?
- '58 Super 88 PS conversion - what's needed?
- 53 Fuel Pump Filter
- Hey Jerry, looky what I got!
- 56 Olds 88 2Dr Hardtop rear quater panel
- 1954 “Trunk lock cover” for a Ninety Eight
- Making foam armrests on the cheap!
- 53 Olds Door Card Removal
- My Olds has arrived
- Which trans lines go where?? Help!!
- How to put together 1956 Steering Wheel Assembly?
- Frame Dimesions
- 1947 Convertible front suspension
- 1936 L36 rear end options
- 1956 2DHT Power window issue
- 1956 Upholstery Project
- 1956 foam armrest
- 1919 headlite parts
- 55 Needle Bearing Kingpins
- A little progress
- '58 olds 371 4 bbl carb Fuel Pumps
- Removing the Gas Gauge- '56
- Beautiful '48 Olds Woody Wagon at Car Show
- 55 Olds throttle linkage
- '55 Used R&L hood hinges on Ebay
- Decode 1958 Super 88 Sedan
- 56' general questions
- Air Ride for a 53?
- Parts manual 1950
- Sunvisor
- New to this site! Need help on a 49
- 57 Super 88 trim question
- what kind of master cylinder
- Spark plugs
- 53 Brake rebuild?
- Generator Color?
- Head Lights and Sacrilege
- Looking for Starter Solenoid or Starter
- 55 Fuel Line Fitting
- 52 Pont sun visor on a 53 88?
- 1955 weatherstripping
- Did Olds make a model 76 convertible in 47?
- 48 Olds 66 coupe
- 55 windshield gasket
- 46-48 Convertible owners and others, What are these?
- 1950 88 Barn Find
- 1953 98 fixes
- 49 olds 88 coupe
- 1938 Australian sloper Oldsmobile
- 48 Olds fuel tank door question
- 56 324 4bbl carb upgrade?
- '50 horn button install
- 1948 Oldsmobile radiator leak
- New to the site - wood frame plans 31 Olds
- Tranny leak question
- Wheel lug and nut size
- Frame for 1940 2 door Olds coupe?
- putting a 394 in a 58 help
- 1948 Oldsmobile club coupe door handle escutcheons
- What steering wheels fit a '48?
- Battery checks good but not charging
- 56 front drum
- Old School Wheels
- 47 Coupe dash width question
- changed wheel
- 56 Fuel gauge problems
- vin location 1940 olds 2 door sedan
- 455 in a 1956 olds anyone
- 55 Holiday again
- '48 mod 66 Rear shocks and links
- 56 headlight swith
- 371 oil pan leak
- intake gasket
- A Nice norwegian registrated olds here.
- Gasket Changes 1948 Olds 257 Cu In L8
- Chris's 57
- Looking for '55 Speedometer or dash cluster
- which carb?
- 1941Olds fuel tank
- '48 model 66 front brake lines
- Heater motor Olds 53
- 47 Oldsmobile Parts - Solenoid Switch
- Show us your '58 Olds "Chromemobile"!
- 55 Dual Exhaust
- parts wanted
- front axle nut
- 1948 model 60 steering column lubrication
- NEED PIC of '58 Super 88 4 dr Sedan seats
- 1952 Olds 88 Sedan build
- 55 324 lifter noise
- Battery cables
- 56 ignition ballast wire removal
- shocks
- 56 Super 88 Heater/ Defroster/ AC question
- 1955 Olds special bolt
- 1956 Olds 88 dual exhaust conversion
- Need some help-Valiant controls for Vets
- 1954-1956 owners
- 1956 88 Gas pedal catching
- 48 Olds Club Coupe Kustomized
- Wipers or wiper Switch ('55 Olds)
- 1938 interior
- F-28 serial number
- 1956 4bl carb help
- 1956 Tank strap
- !956 Super 88 with ps Pitman arm work with a 605?
- 1936 coupe
- 1952 88 Brake problem
- Just Saved a Bunch on a new Gas tank
- New Springs on the '55, found gas tank leaking!
- Series 66 Club Coupé in Sweden
- Recent Vibration
- Decided not to paint... Right choice?
- Oil filter
- 1948 Olds 78 (L8) Generatot
- Vacuum connections for J2 carbs
- 1957 Bendix and Moraine
- 1957 J2 center carburetor
- 1956 4gc Carb linkage
- want to decode cowl tag
- Adapter Kits
- oil filter element
- 1949 Clock Help Needed
- 1957 rear fender support bracket?
- 56 Power Steering Box Seals
- 1957 98 - Engine stalls idling on a hill
- Main bearing oil seal- 238c.i.
- 1938 coupe update
- Need 1941 park light bezel
- Need differential info for a 48, 66 convertible
- FREE Stuff for 1939 - Pay it Forward
- Need exhaust parts for 54 Super88
- Blue Glass?
- Looking for a 57?????
- 51 olds bumper
- '39 F-60 4 door seats
- 57 Olds fuel pump
- disk brakes on a 48
- Finallly Getting the Super 88 on the road
- Newbie: is this a 1913 Olds?
- 324 freeze plugs
- 1940 Business coupe Patch Panels?
- 1948 98
- Burlap for engine compartment
- 1948 Olds gear ratio?
- 1938 inside door handles and cranks
- 56 Parking Brake Warning Light
- 1954 98 turn signals
- VIN decoding
- finally done
- 1950 olds 88 engine paint
- 1950 olds 88 coupe floor braces
- 1938 opera coupe
- 50 olds 88 rear bumper filler?
- rebuilding a 303 rocket engine
- What is the correct accessorie spotlight
- How to identify a straight 8 manual flywheel
- 1948 model 66 engine swap question
- 58 Super 88 on Kijiji
- my 56 rat rod ....
- need a little help
- 1955 Starfire convertible...SOLD
- Noise In Front When Turning ('55 Olds)
- windshield replacement on a 1953 98
- Ranmat
- starter for 55 needed
- Poor illumination on inside turn signal indecators
- VIN identification
- Brake hoses
- 1954 transmission finish
- 54 master cylinder needed (power brakes version)
- '55 olds 88 wiper motor
- 55 Super 88
- Carter WDO 650SA Carburetor
- Desperately need oil pump, tube, screen for 54 324ci
- 1950 olds 88 brake shoes?
- Engine paint colors
- 1950 olds 88 exterior sun visor question
- 1950 olds 88 model issue?
- 56 Holiday 98
- Acceptable Oil Pressure?
- is it possible to repair grill bars?
- 1950 88 starting issues?
- Generator Pulley for 54 Olds Super 88
- A/C for 1951 olds rocket 88
- 50 OLDS 88 in need of doors
- question about all underhood wiring
- 1950 gas line?
- 6 volt or convert to 12 volt
- Starting Issue
- 57- Choke
- Trunk Light
- 1949 Full custom street rod for sale
- 1955 Olds exhaust system
- Capacities for 31
- 57 Olds replacement radio
- 1955 Olds Motor Mounts
- Roof Canvas on a 1931 Patrician
- Rubber Seal Breakdown
- 54 vs 55 doors
- Pertronix Ignition
- Seat Belts
- 1956 glass
- jetway/hyra-matic and more
- 1947 76 or 66 Olds
- Difference in 54 Super88 and 88 - and where to find parts?
- 1946, 1947, 1948 Olds owners - I want your opinions.
- Tag decode
- 1957 Oldsmobile washer parts
- 1955 Olds Front Wheel Bearings
