Posi-traction in 55 Olds rearend
Old Jan 20, 2016 | 09:08 AM
Olds Scott's Avatar
Was posi-traction offered in 1955 Oldsmobiles? If not is there a unit that I can install in my stock 55?
Old Jan 20, 2016 | 04:09 PM
chequenman's Avatar
The earliest I've seen a Posi in an Olds was 1957.
Old Jan 20, 2016 | 04:21 PM
citcapp's Avatar
Nope, as stated no Posi until 1957. Your pumpkin is different and will not accept a 57 Posi even if you could find one. There is a aftermarket unit that will fit the 58 and up with 32 splines so if you wanted posi you would need to go with a 58 thru 64 housing and retro fit into you 56. or use a later GM setup that matches your width but your bolt pattern would change in the rear
Old Jan 20, 2016 | 04:42 PM
Tedd Thompson's Avatar
Doubtful you could spin both tires with a stock 324, what are your plans that you would need a posi.... Tedd
Old Jan 20, 2016 | 05:51 PM
Olds Scott's Avatar
Just kicking around the idea but sounds like a no go. Thanks for the feed back
travisbeamon
May 22, 2013 11:00 AM
travisbeamon
Drivetrain/Differentials
Nov 29, 2012 07:12 PM
ScottoW31
Feb 21, 2012 03:36 PM
Bob Kelso
Sep 17, 2011 06:14 AM
wash464
Aug 26, 2009 05:47 AM
