57- Choke
Old Apr 6, 2014 | 05:21 PM
Mark57's Avatar
57- Choke
Tried starting the car today and found it reluctant to run. Had a look at the choke and found it wasn't closed which I assume being cold in the shop it should be closed. Found that the thermostat spring wasn't hooked to choke piston and found the baffle plate all rotted out, see picture.
Looks like I'll be doing some searching to find one of these baffles. All the rust from the baffle had everything stuck good inside.
Mark
Old Apr 6, 2014 | 06:24 PM
Rocketowner's Avatar
Mark57,just saw a '57 Olds. Choke baffle plate listed on Ebay for $29.95 + $5.50 shipping.Had GM Box with part # listed.Good luck, Larry
Old Apr 7, 2014 | 02:42 PM
Mark57's Avatar
Thanks Larry, I found an old bulletin with the carb parts listed so I at least had the OEM number to search with. I will be ordering this tonight.
Not sure if it will help my starting issue but at least I can get the choke together properly.
Mark
Old Apr 14, 2014 | 05:02 PM
Mark57's Avatar
I put the new baffle plate in and set the choke thermostat spring up for proper tension and all is well. I had noticed some hard starts last year but thought that was mostly due to lack of use before I bought it. Started up with one pump of the pedal. The choke opened up as it warmed up and idled fine.
Mark
240 Gordy
Oct 11, 2020 10:04 AM
2 door cut
Aug 30, 2006 07:03 PM
perksolds
Aug 24, 2006 07:34 PM
Poetry Rod
Feb 22, 2006 08:05 AM
Poetry Rod
Feb 18, 2006 09:51 AM
