1955 Olds rear anti sway bar bushings
Old Feb 18, 2016 | 05:41 PM
Olds Scott's Avatar
Are rear sway bars thinner than the front sway bar? I found the correct ones for the front bar that have a 11/16" diameter hole but the rear bar is only a 1/2" diameter bar. Fusick does not show the smaller diameter bushing on their website, they recommended calling NAPA to cross reference. Steele rubber also only shows the front bushings on their website. Would appreciate any good feedback.
Old Feb 18, 2016 | 06:48 PM
Rocketowner's Avatar
Scott,are you sure about the size of the rear sway bushings.Not really doubting you, but the 1955 Chevrolet rear sway bar I found on the internet says they are 8.75 which is a 7/8".
Larry
Old Feb 18, 2016 | 10:33 PM
Olds Scott's Avatar
Larry
No I used a caliber to measure my sway bar and it came up a 1/2".
Old Feb 19, 2016 | 05:33 AM
jozw30's Avatar
The rear bar is thinner (makes me smile every time I look at it....).
The bush in is the same either way. It smashes down pretty good when you tighten the bracket. The Fusick part description says its for both. They also have the end link assemblies for the rear.
It all went together fine for me on my last mock up.
Old Feb 19, 2016 | 07:42 AM
Olds Scott's Avatar
I will also mock it up and take pictures of the fit later on today.
Old Feb 25, 2016 | 08:12 AM
Olds Scott's Avatar
Turned out that a 5/8" and 9/16" bushings are too big for the stock clamp. With 2 coats of POR 15 the diameter is 1/2" so it seems the only alternative is a poly bushing 7/16" diameter with it own clamp and can be lubricated. Waiting for them to arrive in the mail and will let you know how it turns out.
Old Mar 5, 2016 | 01:37 PM
DFitz's Avatar
74 2.8L Capri
Olds Scott,
I had this same exact conversation with Fusick about 2 years ago. It turns out that depending on where your car was built, it may have had the thinner rear sway bar. Mine does.
These bushings are fairly generic. I bought this from Auto Zone and it worked fine. I also sent that info to Fusick to include in their catalog, but they weren't interested.
http://www.autozone.com/1/products/1...n-9-5102g.html
Railguy
Jan 20, 2016 07:07 PM
oldrelics
Mar 31, 2014 10:10 AM
DRXOLDS
Paint
Dec 28, 2011 08:09 AM
Lady72nRob71
70
Oct 10, 2011 11:33 AM
Bluevista
Drivetrain/Differentials
Jun 7, 2010 06:14 PM
