1955 Olds Front Wheel Bearings
Has anyone converted the front wheel bearings from the older ball bearings to the newer roller bearings. I had heard that the 57 Olds bearings can be used with remanufactured races to fit the 55 hub and spindle. One of the upgrades I want to due for safety purposes.
Olds designed these bearings to carry several times the load that they will ever carry.
I think the main reason that GM went over to roller bearings was that they were cheaper.
My advice is to clean the bearings thoroghly . Inspect the bearings and races for pitting or rust. if they look good, pack them with good wheel bearing grease and " roll on ".
Ball Bearings vs. taper Bearings......
You guys are on the money with the fact that taper bearings are much cheaper... and there was 1 company that experimented with replacement taper bearings for ball bearing applications -- it was a pretty red, white, and blue box -- called appropriately enough "American" Bearings... unfortunately, they went out of business a long time ago.....
The '55 - '57 Chevy world has "reproduced" their bearings in a taper replacement, but unfortunately, they don't fit Oldsmobiles......
Stay away from these Bearings of today (you guessed it -- china -- and their ***** are held in with plastic cages -- junk.....)
If replacing Ball Bearings -- you must use "NEW OLD STOCK" -- and I do have some, not a lot, for OLDSMOBILES -- 1935 thru 1961 !!!!!!!
Best to call me -- craig -- 516 - 485 - 1935... New York.....
Tapered roller bearings are less sensitive to contamination and the added surface area distributes load. My ball bearings on my '56 Chevy were nothing but trouble. But, I was only 15 when I bought the car and was more interested in partying than in maintenance
Measure the spindle diameters where the ballbearings sat and the distance between both seats. If they match up with another model, you've got it easy. If not, machine accordingly.
Just found this, while looking up spindles: http://www.streetrodderweb.com/featu...8/viewall.html
Before you buy the outer bearing,check your local bearing shop. Last ones I bought were 20 bucks and change, BO1 sounds familiar, and he said he could supply as many as I needed-for a 56 but similar for earlier. Same goes for all bearings. Remove-take to bearing shop and see what they have on the shelf. Bo1 is the outer and Bo2 is the inner,909001 is outer number fusick uses and 909062 is the inner number.
Andrew240
Dec 22, 2007 01:54 PM
