PDA
View Full Version : Vintage Oldsmobiles
Pages : 1 2 3 4 5 6 7 [8] 9
  1. 324 pulling help!!
  2. canadian car
  3. canadian car
  4. Tilt Hood Project for 46-48 Oldsmobiles
  5. 49 model 76 project
  6. All 59 Owners Check In
  7. Pictures of '56 Olds 98
  8. No sparky sparky
  9. Saying Hi....
  10. 49-50 Olds rear suspension
  11. Found my hood! Update
  12. 37 Oil leak
  13. 37 wiper motor
  14. trim clips
  15. oil bath air breather
  16. Are any mid 50s parts date-coded?
  17. decoding
  18. Looking for part
  19. average cost of average interior
  20. Correct distributor, 1955 324 w/ Hydromatic, w/o air
  21. Oil bath to paper air filter - 55 batwing 324ci
  22. 1950 Rocket 88 gas tank
  23. trying to put pics on
  24. '55 98 4 dr pass front door stainless trim cheap
  25. extended search 55 hood up date
  26. 46-47 olds coupe
  27. 55 hood help needed
  28. 1937 Olds fuel pump
  29. Wiper motor information vacuum to electric
  30. 1940 Diff pinion thrust washers
  31. Fenton Headers for 303/324 - Please Explain
  32. 54-88 heater hose routing
  33. Start Me Up...If you Can - 55 Olds
  34. 56 4 door hardtop measurements needed
  35. 1937 Fuel Pump ?
  36. Parts car ?
  37. parts
  38. Anyone know how well parts interchange
  39. 1956 olds mystery holes
  40. what year?
  41. headlight bucket gasket
  42. 47 oldsmobile
  43. 56 88 steering arm?
  44. 34 parts needed
  45. Olds 371 exhaust manifolds wtb
  46. can i see your seats
  47. 1946 1947 and 1948 How many own them?
  48. 1956 olds holiday 88 4dr windshield help
  49. Master Cylinder filler tube
  50. Windsheild Wiper
  51. '46-7 Hood Latch
  52. 1940 grille
  53. 1940 olds info needed
  54. hooking up tach meter for rpm adjustments
  55. curved dash order form
  56. Two-tones 56 two door sedans
  57. 56 Olds: What am I to do with the GAP?
  58. 58 Dash Info
  59. 37 olds parts needed
  60. squirters
  61. PerTronix Electronic Ignition on my 55-20 minutes--ha!
  62. Wiper Chain repair/replacement 40s Olds
  63. Dual exhaust Options for 52 S88 Coupe
  64. bumpers
  65. help with feul pump vacume lines
  66. Car Covers, Waterproof and/or dust covers
  67. Horn button needed '55 olds
  68. Shiny bumper stuff-old car
  69. 53 steering box removal
  70. rear trans mounts
  71. 56 Olds HIGH Temperature control lamp
  72. 56 Carb opinions
  73. 56 gas tank
  74. Hydramatic Quick Change
  75. '56 88 troubles
  76. '55 2 Door Post 3-speed Restoration
  77. Mystery Harness on Seemingly all 55's
  78. Standard Shift Neutral Safety Switch
  79. Super Hydra-Matic
  80. just saw this on craigslist 2 1956 98s
  81. Need 2 Door Sedan Moulding-1955
  82. 56 Trans fluid
  83. 56 over heating
  84. 1957 suspension rebuild.
  85. 1956 bog and surging problem
  86. drivers front door glass
  87. Parts interchangability
  88. installing 455 in 1956 oldsmobile ?
  89. 1956 intake manifold
  90. Could not help myself
  91. 56 Super 88 Conv: Where is the conv top pump?
  92. My "adventure" buying a 56 Olds Super 88 Conv + driving it in Germany the first time
  93. Radiator 1956
  94. Electrical
  95. Paying for Information
  96. Sent Another One Down the Road...
  97. Need Data sheet for 1956 Oldsmobile Super 88 Conv.
  98. In desperate need of 56 front fenders!!!!!!!
  99. Ride in the '55
  100. Gas tank replacement
  101. Edna On Her Way To Her New Rightful Owner
  102. 1946 Dealer Showroom Album
  103. Oh, NO! I need some Advice - Pics
  104. Glove Box Door Lock/Button
  105. VIN Tag Replacement
  106. 56 olds edelbrock carb swap
  107. Parts breakdown of distributor
  108. Identifying and Selling a J-2
  109. Be careful when you order a restored carburetor!!!
  110. Horn ring removal on 55
  111. Hood Springs for 1956
  112. Just bought a pretty rare '55
  113. 39 Olds 70 series fender?
  114. Pls help!!! Do I need a new crankshaft for the 56 S88?
  115. Need help plumbing
  116. 2 '55 s-88
  117. Heelp! Is it risky to drive the car? worn cam? -56 olds
  118. got this decal
  119. Question about 56 Olds
  120. Why is it so hard to find info and parts?
  121. 1940 60 rear axle mounts
  122. 55 Olds Trim Tag Decoding
  123. How the hell do these drag links come apart???
  124. Having a hard time throwing things out...
  125. 1966 oldsmobile dealer book
  126. Modern Hollander for the 56 Olds.
  127. performance exhaust headders
  128. 41-48 Instruments and sheet metal
  129. 56 Olds trunk lid insulation
  130. Friday the 13th....Starter.
  131. '41 4-door for sale
  132. 1940 olds exhaust manifold
  133. Should I buy a 1941 Coupe?
  134. Ebay floor patches?
  135. Frame off Dave
  136. What engine will fit without modification in '57 Oldsmobile
  137. 61 Starfire
  138. What was the color of the Jetaway in 56?
  139. Pls help with the correct Trim Tag numbers
  140. Someone Talk Me Out of This...
  141. 56 olds on ebay
  142. 1956 Power Seat Switch FS: interchage other years?
  143. 46-48 gas filler tube set up
  144. Decoding Trim plate and deluxe question
  145. Rear shocks?
  146. eccentric bolts?????????
  147. Alternator mounts on a 324.
  148. '56 Doors interchance
  149. "57 Rocket 88 How is the name of the part?
  150. Pics of 46-47-48 Needed
  151. Need an old 1956 TRIM TAG
  152. It's been awhile
  153. 324 starter?
  154. heater control valve rebuild
  155. 1928 olds repair or service manuals
  156. 1955 88 back window molding removal?
  157. Cracked power steering manifold?
  158. Engine swap to modern olds engine
  159. ID for '56 Olds Power Brakes
  160. found in Italy
  161. question on my 56 olds
  162. 55 olds fuel pump
  163. 1941 Olds engine pictures
  164. olds 55 4 door hard top
  165. 1941 Olds paint question
  166. What would you pay for a parts car?
  167. Have you seen one of these and what is it worth?
  168. Vintage part resources?
  169. Part numbers needed.
  170. pictures
  171. NEED: 4-page Instructions for mounting all-plexiglass hood to 1949 "88"
  172. i need help......
  173. 37 olds been stored since 56
  174. anyone know of '56 4dr 98 for parts?
  175. pics
  176. Front shocks.
  177. 1939 olds parts
  178. 55 olds fuel pump
  179. 1940 rear bumper gravel deflector
  180. HEI for a 56 324?
  181. Wanted: '57 Olds power window help
  182. 59 olds 98 airconditioner
  183. need adj pushrod or rocker 324
  184. front chrome clips 1955 olds
  185. I can't leave anything alone!
  186. 57 olds parts
  187. 57 olds- fuel pump info
  188. opinions wanted. With or without skirts?
  189. 47 Trunk Lock Info Wanted
  190. the old girl gets new paint!
  191. what have i bought
  192. Intake for 303-324
  193. 47 Coupe Stock Radio removal
  194. 56 Olds window regulator diagrams?
  195. Please help ID this part...
  196. vacume tank 55 olds
  197. 1949 olds plexiglass hood
  198. ad on oiling OLD SCHOOL HOT ROD
  199. How sweet!
  200. Ideas for parts for restoration of '41 Olds
  201. valve covers
  202. 47 steering wheel on newer GM column?
  203. Jet Hood Emblem
  204. The big surprise revealed!!
  205. Window Leaks
  206. continental kits?
  207. 1955 Oldsmobile
  208. '47 Olds steering wheel
  209. 56 Hydramatic Filter
  210. new guy
  211. Looking for headers for a 62 394 V8 Dynamic 88?
  212. Manifolds
  213. 56 park/turn signal wiring
  214. 1927 REO ? Please Inform
  215. Power Steering on 55 Olds
  216. Power brakes on 55 olds
  217. 57 Olds tailight question
  218. Manual trans for 1964 olsd 98
  219. drum brakes pulls to the left, olds -56
  220. 41 Olds oil pump
  221. My dad's 56 (late 50's)
  222. '54 Oldsmobile 88 in Street Rodder
  223. How can I convert a 1962 394 single quad 2 bbl into a 4bbl
  224. 55 fuel gauge
  225. dead battery
  226. New tires for the old girl
  227. steering box upgrade for '56?
  228. HELP!! 1956 Master cylinder for power brakes
  229. 1957 Olds Door panel clips.
  230. 55 radiator
  231. Ebay fuel sender
  232. 1940 dilemma
  233. Brake question
  234. Updated driveline for '47 Olds
  235. Need new shocks for the 55
  236. Power steering pump rebuild.
  237. turn signal cancel cam
  238. Dual action fuel pump
  239. brake help needed for a 55
  240. Wiring courtesy lights in a 1956 olds
  241. Oil pan removal 57 Olds 98
  242. Won't kickdown
  243. 4gc Carb Rebuild
  244. What size tires for 56?
  245. Pertronix help
  246. Electrical fire!
  247. 57 olds trim fasteners
  248. Rebuilding vacuum slectors/57 olds
  249. Under floor brake pedal setup for 47 Olds
  250. all 56 owners ck in
