ID for '56 Olds Power Brakes
Old Jan 3, 2011 | 09:30 AM
holidaysedan's Avatar
Is there an easy way to ID whether a 56 Olds has Bendix or Delco Moraine Power Brakes?
Old Jan 3, 2011 | 02:17 PM
hialeah56's Avatar
1956 holiday coupe
If I'm not wrong the master cylinder on a delco moraine is attached with 4 bolts to the booster and the base looks square, on the Bendix it's 3 bolts and the base would be triangular (see pics)
Old Jan 3, 2011 | 02:38 PM
hialeah56's Avatar
1956 holiday coupe
btw this is a bendix style I just sold. See how the bottom of the base of the master comes comes to a point
Old Jan 4, 2011 | 07:23 AM
Thanks! Are the 2 interchangeable, ie: could I replace a Bendix on my 98 with a Delco-Moraine unit?
Old Jan 4, 2011 | 06:46 PM
hialeah56's Avatar
1956 holiday coupe
I'm sure they are, if you look at the booster, the side that mounts up against the floor looks identical on both and the part where the line screws into also looks the same. They both came in all 56 models equiped with p/b so I don't see why not
Old Apr 15, 2011 | 08:30 AM
Frank Allen's Avatar
power brake
56 could be bendix or moraine, either will work on 56, they interchange from 54 to 57 all models with power brake set up. not sure about 58 etc, but through the yrs ive used these from the models described without a problem
Frank Allen
Old Oct 9, 2011 | 02:48 PM
55miketn's Avatar
Railroad Mike
moraine brakes
Frank Allen
Do you know where I might obtain a rebuild kit for the moraine booster and master cyl. for 1955?
Old Oct 9, 2011 | 03:14 PM
hialeah56's Avatar
1956 holiday coupe
Try the kanter link in my signature. If you look under 55 it will only show a bendix kit but I'm sure if you get in contact with them they could either direct you in the right direction or have one in stock. Their website is not the greatest but they are always happy to help
Old Oct 12, 2011 | 11:41 AM
55miketn's Avatar
Railroad Mike
Checked it out. Success for some parts. Thanks!
Old Oct 12, 2011 | 03:26 PM
hialeah56's Avatar
1956 holiday coupe
no problem btw nice 55
Old Oct 12, 2011 | 04:28 PM
Super88-56's Avatar
I've had some luck obtaining rebuild pbrake cylinder parts for my '56 from NAPA. Cheaper price and faster delivery. I used the Fussick catalog as NAPA can cross reference the part numbers.
Old Jun 3, 2012 | 10:12 AM
lekingg's Avatar
hello I have a problem with the power brake I just get on my oldsmobile (rebuilt by fusick automotive)) Rubber hoses are new and empty the tank tested Started the engine is pressing the brake pedal and it is supported by the wheel brakes are locked on the pedals off the engine and back wheel is released I do not understand. you would need a track or he replaced the power brake. (I'm stuck in the reconstruction of oldsmobile by themselves Song) thank you
Old Jun 4, 2012 | 12:42 PM
55miketn's Avatar
Railroad Mike
If Fusic rebuilt the unit it should junction properly. Did you bench bleed the master cyl. before installing? After installing, did you bleed all 4 wheels starting from r.rear,left rear, right front, left front.? If all this is good, you should be able to put your foot on the pedal and start the engine. If the vacuum is working, the pedal should go down when the engine starts. You need to adjust the shoes to the drums also. There is a check valve in the vacuum hose from the manifold to the vacuum canister under the floor. You can pull the line off the downstream side and see if there is any vacuum there. If not, the check may be inoperative. Good Luck!
Old Jun 5, 2012 | 08:55 AM
lekingg's Avatar
hi, when I unplug the pipes of the air intake the engine stalls is this normal? the vacuum is good but I have a pipe leading from the brake power to the tank under the floor but I do not see a valve or check valve would you shema or photos.
Old Jun 6, 2012 | 09:02 AM
Russ P in MD's Avatar
I don't have one in front of me to reference, but you may want to invest in a 1955 Oldsmobile Shop Manual. You can find them on eBay and Amazon, book or CD format.
Old Jun 9, 2012 | 05:24 AM
lekingg's Avatar
ok thank you but I already have a manual on cd but I can not find the solution.je not find a check valve between the carburetor and the brake power on the schematic of the manual shows a check valve between the carburetor and pipes of air that may have a photo of this valve.???
Old Jun 15, 2012 | 11:51 PM
rebel's Avatar
My 56 Olds 98 has P/B, on some occassions when I press the brake especially when I get on the gas a bit, the pedal goes to the floor. I need to pump it to get the brakes working. What is happening and what do I need to do?
Old Jun 16, 2012 | 12:56 AM
oldsmobum's Avatar
Yes there should be a check valve between the booster and the base of the carburetor. Any vacuum check valve from a parts store with the right size vacuum fittings should work. Other than that I was not able to understand what the issue you were having was...
Old Jun 18, 2012 | 01:35 PM
55miketn's Avatar
Railroad Mike
Unhappy power brake blues!!
The check valve is on the end of the metal line coming out the rear of the base of the carburator. The metal line screws into the check valve( which is a metal thing about 2 inches long) and has a hose clamped onto the end of that. The hose goes to the brake booster AND the vaacuum storage tank mounted on the driver's side of the frame. If you unplug the vacuum line from the engine, yes it will stall. Any vacuum leak will kill performance and hurt the operation of the power brakes. Put your foot on the brake pedal and apply pressure; start the engine; if the pedal goes down, the power unit is working. If no brakes, check the shoes, adjustment, air in lines, etc. Good luck!!
Railroad Mike
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
Uly49
Oct 20, 2009 07:11 PM
Threejdsolds
Jun 12, 2009 07:52 AM
