Hood Springs for 1956
Old July 17th, 2011, 02:59 PM
jaymann's Avatar
Hi Everyone!
Any leads as to where I might find some hood springs for a '56?
The originals are too weak to hold the hood open.
I can't seem to find any online.
55-56-57 Chevy repops look too short.
jaymann is offline
Old July 24th, 2011, 06:19 PM
Collector of Stray 55's
Olds Dad's Avatar
Hi - I've been looking for the same for '55 - same problem - keep us posted if you locate...I'm having no luck either - seems a common problem - wonder what the costs to repop would be...
Olds Dad is offline
Old July 16th, 2015, 11:04 PM
olds5556's Avatar
56 olds hood springs
I'm looking for a set too. I bought a set of NOS 56 Pontiac springs hoping they would be the same, but they weren't. They are probably the same as chevy hood springs. My passenger side of the hood doesn't close all the way. I think the spring is week. Maybe Fusick Olds in CT. would have them ?
olds5556 is offline
Old July 17th, 2015, 05:30 AM
Rocketowner's Avatar
Smile
If you could have someone to closely watch where the (large rivets) go through the hinge while you wiggle the hood up and down slowly, you will see movement that indicates that the holes are worn oblong up and down. They will need to be welded and drilled back true, and the rivets replaced.I have seen the rivets available on the Internet at times.There's also some places that rebuild them , but that main pivot location in The middle of hinge is usually the problem. Good luck . part # 2887 From Danchuck Chev. parts ,is oversize hood hinge replacement rivets.So you can just drill them to new rivet size without welding.$32.00 for 4 Rivets. Good luck , Larry
Rocketowner is offline
Old July 17th, 2015, 09:43 AM
Ozzie's Avatar
The hood hinge springs are the same for the 1953-56 Olds; group number 8.013; part number 568683. Chevrolet never used the part.
Ozzie is offline
Old July 17th, 2015, 09:56 AM
Sorry , I was thinking about Hood hinges.I Looked forever for a set of Hinges and finally found a used set.Have not replaced the worn one yet ,it just won't pull the hood completely down at the passenger side back edge of hood. Larry
Old July 17th, 2015, 10:06 AM
Ozzie's Avatar
Hidden Valley Auto Parts; Maricopa, AZ; 602-252-2122; 520-568-2945; claims to have both (used) hinges from a '56 Olds. This may include the springs.(?) Call or e-mail for a price.
Ozzie is offline
Old July 17th, 2015, 10:12 AM
Tedd Thompson's Avatar
Has anyone checked to see if Cadillac or Buick cross over. Many body parts are the same on Buick and a few that I know about on Cadillac? Generally not many Chevy or Pontiac interchange unless it's early 30's 40's.....Tedd
Tedd Thompson is online now
Old March 28th, 2017, 01:55 PM
Olds Scott's Avatar
Just installed my hood and checked alignment and it seemed good. Used the floor jack and washer method to stretch spring for installation and that worked well also. Like the rest of you it seems my springs have lost their tension over time and need replacing. Do not want to go used or NOS for these parts but have not found anyone making new Olds springs. My hinge rivets and hood bolts are in good shape and the action is good, just not tension. Must be a crossover part somewhere
Olds Scott is offline
Old March 28th, 2017, 03:41 PM
This post is almost three years old but the problem is still very current. Anybody found a Repo replacement?.... Tedd
Old March 29th, 2017, 05:36 PM
TRWham's Avatar
I have identified a spring from Century Spring (Stock No 5381) that seems to be very close. The overall length and diameter are about right, but the wire diameter is a little larger (0.312" vs 0.250"). They are about $50 each and I took the risk and have ordered a pair to see how well they might work.
http://www.centuryspring.com/
TRWham is offline
Old March 29th, 2017, 06:03 PM
If the springs don't work out,I have a good drivers side hinge complete with spring .I wasn't thinking about selling it,but if you need it I would take $40.00 for it plus shipping. Larry
Old March 29th, 2017, 06:22 PM
TRWham's Avatar
Thanks!
TRWham is offline
Old March 30th, 2017, 06:26 PM
74 2.8L Capri
DFitz's Avatar
I just bang my head every time I go by the corner of the hood. Gets pretty bloody.
DFitz is offline
Old March 30th, 2017, 08:45 PM
I use a 4 to 8 foot paint extension after about 100 hits to the head I thought I should do something different, that worked out well.... Tedd
Old April 2nd, 2017, 08:14 AM
TRWham's Avatar
These springs have shipped. I will report results once they arrive and we have a chance to test them.
TRWham is offline
Old April 9th, 2017, 02:39 PM
Olds Scott's Avatar
Looking forward to the results of the test.
Old April 10th, 2017, 08:58 AM
TRWham's Avatar
Okay, a quick side by side comparison shows these are a bit long. Diameter is good, but I will need to swap one into a hinge to see if the length is an issue in use. We may need to rework the spring to shorten it. Stay tuned.
TRWham is offline
Old April 10th, 2017, 05:16 PM
Olds Scott's Avatar
Are you comparing the length to OEM spring?
Old April 10th, 2017, 06:55 PM
TRWham's Avatar
Yes.
TRWham is offline
Old April 16th, 2017, 03:17 PM
Olds Scott's Avatar
How is the alternate hood spring comparison going?
Old April 19th, 2017, 03:26 PM
TRWham's Avatar
We've been distracted by a few other things. Will let everyone know as soon as we can test fit one.
TRWham is offline
Old April 22nd, 2017, 05:58 PM
TRWham's Avatar
Okay, I am going to declare victory and say these are viable with minimal modification. I did cut about 1/3 of the hooks off to allow the new spring to fit, but it does the job. The Century springs are slightly larger diameter and longer, and the wire is a bit bigger. I have no reliable means to compare spring rates or force, but the larger coil diameter somewhat offsets the impact of the larger wire and I imagine these are pretty close to OEM strength.
These do stack up sooner than OEM, so it is possible the hood will not open quite as high, but with only one new spring installed, the hood stays up nicely.
Passenger Side '56 Super 88 OEM
Driver Side '56 Super 88 Replacement
TRWham is offline
Old April 22nd, 2017, 07:27 PM
Olds Scott's Avatar
Thanks for the leap of faith investment in these springs. Going to order some on Monday.
Old April 24th, 2017, 05:41 PM
Olds Scott's Avatar
TR could you post a picture of the hood in open position with your new springs installed?
Old April 25th, 2017, 06:59 AM
TRWham's Avatar
The hood holds at about 38" (see photos for measuring points), which is the same as the fancy custom prop rod (i.e. a whittled stick) we got with the car. I failed to measure prior to changing the spring, but I would say this is at least 9" higher than before the new spring.
Keep in mind I only have one new spring in right now, and it replaced a kluged spring (too short and extended with a piece of threaded rod bent into a hook) that may have been weaker than the correct OEM Oldsmobile part. The other side appears to be an original 60 year old GM part. I will take new measurements once we have the other spring installed, if you want to wait for those results.
'56 Super 88
'56 Super 88 Hood Opening Lower
'56 Super 88 Hood Opening Upper
TRWham is offline
Old April 25th, 2017, 07:55 AM
Olds Scott's Avatar
Thanks for the pictures. I am 6' 5" so the height will work well for me. When you get the other spring I will interested in the hinge action with the different stacking action of the spring.
Old April 25th, 2017, 10:38 AM
I too am interested when both spring are installed. This could be the answer to getting rid of many head aches(pun intended)... Tedd
Old April 25th, 2017, 11:47 AM
Olds Scott's Avatar
Copy that, Tedd
Old April 25th, 2017, 05:36 PM
TRWham's Avatar
We installed the passenger side and this lowered the hood by about 1 to 1.5" because of the longer spring and resulting decreased force (not stack up). I have searched for alternative new stock springs with no joy so far. We could have custom springs (10.5" long, 1.75" OD and 0.25" wire) made, with costs ranging from about $250 each for 2 down to $40 or less if we buy 100.
I will probably seek a means of modifying the Century springs to work. The static difference is about 1.75", but I think the new spring has a higher rate, so it may stabilize at a similar length even with a slightly longer static length. I think we only need to shorten an inch or so to make them work, so it may be a matter of flattening the hooks a half inch each (this will not change the spring rate). It also works pretty well with one OEM and one new spring, so that may be an option.
TRWham is offline
Old April 26th, 2017, 11:35 AM
  #31
74 2.8L Capri
DFitz's Avatar
Let us know if you think making a run of springs is viable. I'd spring for a pair!
DFitz is offline
Old April 26th, 2017, 04:54 PM
  #32
Olds Scott's Avatar
Sounds like all we need is 50 guys that need a new set of springs. Under 50 bucks a spring would be great. Can only imagine that there are more than 50 cars with bad hood springs.
Old May 4th, 2017, 06:56 AM
  #33
Olds Scott's Avatar
Hey TR, any luck with spring modification.
Old May 4th, 2017, 01:03 PM
  #34
TRWham's Avatar
I did find another stock alternative spring after all. They're less expensive than the Century springs and I have 2 headed my way. Stand by for updates.
Meanwhile, we are pondering methods to shorten the others if needed.
TRWham is offline
Old May 4th, 2017, 01:36 PM
  #35
Olds Scott's Avatar
Thanks TR, looking forward to hearing from you soon.
Old May 9th, 2017, 02:47 PM
  #36
TRWham's Avatar
Shipped Friday. Tracking shows them in Atlanta as of Sunday AM, with expected delivery yesterday, but no update since then.
TRWham is offline
Old May 9th, 2017, 04:44 PM
  #37
Olds Scott's Avatar
Hope these other springs will do the trick. Any luck with adapting the other ones?
Old May 9th, 2017, 06:41 PM
  #38
TRWham's Avatar
Put that effort on hold until these new ones arrive and are tested. Will need to shorten the others by several coils and reform a hook. Those are 0.312" wire, so it's a bit of work. I have a posse of Lockheed manufacturing engineers on standby if we need to go that route.
Stay tuned...
TRWham is offline
Old May 9th, 2017, 11:00 PM
  #39
Olds Scott's Avatar
I am impressed. Good luck and I will be waiting.
Old May 13th, 2017, 05:07 AM
  #40
TRWham's Avatar
Good news- the springs finally arrived yesterday.
Bad news- they don't work. The spring rate is simply too low.
I am now concerned modifying the first springs will create a spring that is too strong, thus over-stressing the hood when closing and possibly causing it to bend. I will reevaluate the entire situation and determine what our next move is.
TRWham is offline
Quick Reply: Hood Springs for 1956
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
