56 Olds trunk lid insulation
Old May 15, 2011 | 02:19 PM
The_German's Avatar
The trunk lid of my 56 does not have the insulation. It seems the to be the same material as it is used on Chevys and other cars.
I cannot find any pre cut insulation for Olds, however, Fusick dose not have it either.
Any idea, how to solve that problem?
Where can I find the insulation, does not need to be pre- cut.
The_German
Old May 15, 2011 | 08:14 PM
hialeah56's Avatar
1956 holiday coupe
Hi Cord,
Don't quote me on this but I think this is the same material. The original one was made of asphalt tar paper and was the same as the one used under the headliner. Just don't know if this will have the same pattern or thickness as the OG one.
http://cgi.ebay.com/ebaymotors/55-56...Q5fAccessories
Old May 16, 2011 | 08:32 AM
The_German's Avatar
Erit, that seems to be for the roof?
I will contact the guy and see, if he can help.
thanks so much for your help!
Old May 24, 2011 | 06:03 AM
golds56's Avatar
check to see if " year one" has it for chevys check the 56-58 210 versions.
Old May 24, 2011 | 11:21 AM
The_German's Avatar
I found it there, thanks very much!
I just need to double check, if the shapes are the same as in an Olds...
The German
Old May 24, 2011 | 12:47 PM
golds56's Avatar
I used the floorpans and tunnel for a 210 when i did the floors,i also used the side reinforcements with a bit of twisting they were perfect .I got the toe boards from the e bay dude in sc i think.
Old May 24, 2011 | 01:55 PM
56Super88's Avatar
My factory insulation is in very good shape. Would you like a picture of the stock insulation?
Old May 24, 2011 | 04:06 PM
hialeah56's Avatar
1956 holiday coupe
Yeah they are for the roof, but if I remember right when I removed the one on my roof it was the same material and thickness as the trunk one. As for the precut chevy ones look to be a diffent shape
Old May 25, 2011 | 02:55 PM
56Super88's Avatar
Here is a picture of my stock trunk lid.
Old May 26, 2011 | 04:58 PM
hialeah56's Avatar
1956 holiday coupe
and this is what a 55,56,57 chevy look like kinda small I think
Old May 30, 2011 | 07:46 AM
The_German's Avatar
Thanks guys, I will see if I can get the insulation copied.
I will have to cut it by myself, but that should be possible.
shamusj
Apr 7, 2018 08:10 AM
2blu442
Oct 18, 2014 04:55 PM
schipperl
Jan 31, 2014 12:19 PM
70Post
Aug 28, 2012 10:36 AM
Bitburger
Mar 17, 2012 04:04 AM
