Electrical fire!
Old May 2, 2010 | 09:04 PM
jaymann's Avatar
Electrical fire!
I spent the weekend giving the Super 88 a tune up.
New plugs , cap , rotor,wires and a switch to a Pertronix ignition.
Got it running and went to set the timing and poof!
When I twisted the distributor, the metal vacuum advance tube touched the positive wire to the coil. Wow...that sucker lit up like a sparkler. Nothing quite smells like wire burning, it's a smell that gets stuck in your nose. I'm not near the car and I can still smell it.
I guess I'll spend the week rebuilding the wiring harness from the engine to the ignition switch, and I'm ditching that metal line and replacing it with a hose...I don't want that happening again
Old May 2, 2010 | 09:12 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Bummer. Things could have been a lot worse. I like your car.
Old May 3, 2010 | 05:54 AM
Lady72nRob71's Avatar
Ouch! Glad the fire stopped where it did. You might find a way to move the coil away a little bit or fab up a cover for the hot terminal.
Wrenches hitting the positive battery terminal can work better than laxatives...
You are right about the stench of burned wires. Only worse thing is barbequed silicon (fried IC chips). They guys here at work in the lab do that sometimes...
Old May 3, 2010 | 05:58 AM
2blu442's Avatar
Glad it wasn't more serious. That's one of those things that provides more excitement thay any of us need! John
Old May 3, 2010 | 06:58 AM
hialeah56's Avatar
1956 holiday coupe
man that sucks, good luck with the rewire
Old May 3, 2010 | 12:47 PM
jaymann's Avatar
I got it back together. I think what saved it was someone prior to me owning the car re-wrapped the harness with electrical tape. It did a good job of restricting the damage.
I still have to wrap the harness again and tidy things up, but I got it running.
Now I'm having issues with the car running rough....see my post re: pertronix help
Old May 4, 2010 | 05:21 AM
We're glad you are ok.
RustRocket
Sep 5, 2014 10:14 PM
chris83
Jun 10, 2009 10:33 AM
skubydobdo
Oct 25, 2008 04:58 AM
skubydobdo
Sep 26, 2008 11:43 PM
71rocket
Aug 24, 2008 07:03 PM
