PDA
View Full Version : Vintage Oldsmobiles
Pages : 1 2 3 4 5 6 [7] 8 9
  1. 1957 Oldsmobile power steering lower bearing
  2. 1958 Super88 questions
  3. 1950 tudor attaching door hinge sealing strip
  4. 1954 Radiator leak not detectable with air pressure
  5. 1956 Power Antenna
  6. 324 Engine Bolt Specs
  7. 57 2 door tri-power on EBay
  8. 324 / 371 Valve Cover Interchangeability
  9. 1956 Headliner Replacement - Do it Yourself and Get It Right
  10. Oil Pan Gasket
  11. Body Sheet Metal Tape
  12. 1955 Olds valve covers
  13. Getting Back On Road
  14. to buy 1963 starfire?
  15. Removing rust proofing
  16. Radial tires for 57
  17. 1954 Differential Gear Oil
  18. Brake master cylinder access - 1957
  19. 57 Heater Core
  20. 1956 Headliner Replacement - Do it Yourself and Get It Right
  21. Restoring early 30s
  22. 1953 Olds. Fiesta Convertible
  23. New Gas Tanks
  24. engine number
  25. electric choke on '55 s88324
  26. 1946-57 parts book - are there better ones?
  27. Help with a 57 88 J 2 2 door hardtop
  28. In need of 1937-38 8cylinder Olds tail light lens
  29. Drooping door handles on 1940 Sedan
  30. 55 Olds PCV conversion
  31. 55 manuel window regulators
  32. 55 olds trunk light.
  33. insurance
  34. 57-98 Starfire power seats
  35. Valve Cover Braces
  36. 57 J-2 Setup Question
  37. Vacumn Leak?
  38. 1957 371 motor oil
  39. 1957 98 valve covers
  40. carb problems
  41. 1956. 88 engine and transmission removal
  42. the differece betweena 1957-58 1959-60 371
  43. Intake Manifold
  44. 55 Holiday Gas Gage
  45. 1949 98 Flasher Acting Oddly
  46. 49 coupe steering box removal help
  47. welch plugs in the deck of a 59 371 olds block
  48. 1955 Olds Powering Steering
  49. Bellhousing Bolt Pattern 1931-1950
  50. Help with my new 55 Olds:
  51. Great Oldsmobile Collection
  52. Selling my beloved '55
  53. Gas Mileage 324 4 barrell
  54. New look for our 55
  55. Unusual Treadlevac Brake Problem
  56. 1955 324 distributer conversion
  57. Flywheel tool
  58. 55 Olds roof patches
  59. 58 super 88 headlight switch and windscreen wiper switch removal
  60. Wiper Motor?
  61. Olds 1941 238 water pump
  62. AM Radio
  63. 55 Manual master brake cylinder?
  64. 55 Olds Door Hinges - Paint Question
  65. Help identify 1949 50 tail lights?
  66. Front oil "piss" plug
  67. 56 olds motor serial number question
  68. All about Fuses for 1938 olds
  69. 1950 Olds Chassis Manual
  70. will Wheels Exchange?
  71. What model 1935 Oldsmobile?
  72. 1956 holiday sedan parts
  73. 52-56 Oldsmobile Green Engine Paint
  74. looking for '34 Olds parts
  75. want to buy a used 56 olds windshield
  76. Compass...Oldsmobile Accesory or Aftermarket?
  77. 324 Moly piston rings
  78. Piston Rings '41-'48
  79. 1948 Olds 98
  80. Interesting "barn find" -- 1939 Olds
  81. Got the 50 painted
  82. 47' sedan/soon to be woodie cruiser
  83. Wanted: 1956 heads
  84. Starter for a series 66
  85. How much does my engine weigh?
  86. Fender molding needed
  87. gas tank for 1937 olds v8
  88. 56 Super 88 Windshield Washer Question
  89. Need an Electrical Guru
  90. 1954 88 Fender Skirts
  91. shroud
  92. 1955 Olds 88
  93. looking for a 56 sedan windshield
  94. Rocker arms and shaft lubrication
  95. Head bolts or Head Studs
  96. 1955 Front Brake Drum
  97. '57 Questions
  98. 1936 3 window Olds
  99. 1939 olds series 60 steering
  100. 1954 Oldsmobile Color Wiring Diagram???
  101. 1941 starter
  102. 394 in a 56 Olds?
  103. Finally Got Bendix Treadle Vac Fixed
  104. Disassemble trunk mechanism on 41
  105. 1954 Trailer Hitch??
  106. 1949 Body Plate Trim Question
  107. '41 Olds Chassis Number
  108. '53 Super 88 303 oil drain plug/pan
  109. Another Dumb ? This One About Brake Lights
  110. Ammeter Question
  111. 49 303 teardown
  112. 49 Olds 88 heater switch removal ???
  113. How to bar over a motor?
  114. Fender skirts
  115. '41 Olds 66 parts needed!
  116. 49 & 50 98 Door Latch Question
  117. 1954 Owners Manual and Owners Portfolio from Eanes Motor Company
  118. An old Olds in an Olds at Portland Roadster Show
  119. 1949/1950 Oldsmobile trim parts
  120. Any Tredle-Vac guys out there, I need advise
  121. RARE 55-58 OLds factory originaL FLOOR MATS??
  122. New owner of a 38 L38
  123. Power windows 56 Olds 98
  124. 1949 98 Fuse Box Location
  125. 1949 98 Door Latch Help Needed
  126. 1949 98 Seat Question
  127. Need 1949 Body Plate Decoded
  128. 1947 Olds Dynamic 76 Sedan third member interchanges
  129. 55 generator question
  130. upholstry items
  131. Rocketowner's '55 NEW PICTURES
  132. Treadle Vac Brake Question?
  133. Steering worm Series 76 -42
  134. Need a non~existant part
  135. 1950 Olds 88 Club Coupe question
  136. Looking for a 324 Olds V8
  137. Newbie here
  138. inline 8 cyl wanted
  139. avitar change
  140. Beautiful old clock but ???
  141. frame questions.
  142. model number tag decoding
  143. Production # for 1937 Olds
  144. Flywheel cover
  145. Lowrider 56 Olds?
  146. Few 56 questions
  147. Looking for a few things for my 56 olds!
  148. check valve(air)
  149. Attention 41-48 Owners: Convertible project available in Spokane WA
  150. A new subgroup under Vintage?
  151. 1956 Manual steering Box Olds Will it be a direct swap in a 1955 olds
  152. 55 olds flywheel cluch and pressure plate
  153. accessory oil filter
  154. Thermostat housing
  155. Resetting 55 Door Glass, 2 DR HT
  156. 57 olds 98 convertible rear bump outs
  157. trans and rearend
  158. 1955 rechromed hood lip as seen in JWO
  159. Nice Matching pair
  160. '56 hood plane with light??? whats with that? with pics.
  161. Original engine for an F37?
  162. Rochester 4 Jet Stumble Fixed
  163. 1956 oldsmobile illustrated outside stainless trim charts
  164. Vacuum Washer Pump Rebuild - Interest?
  165. Dash pad renewal-spray painting the instrument panel-switch renewal-heater rebuild-..
  166. different linkage for 1957 1958 J-2 multi carbs ?
  167. What to look for on an F35
  168. 54-56 Heater core interchange?
  169. 1955 olds 98 convertible
  170. What type of trans fluid for 1940?
  171. Riveting Discussion...'55 Olds and more
  172. How does she sound?
  173. 1953 Super 88 - Name That Part
  174. Under Floor Power Brakes - 1955 Olds
  175. '53 Super 88 Oil Filter Location
  176. Pics of my project
  177. Assembly Line Stampings
  178. 55 headlight bucket to fender seals
  179. Trying to save a 1956 Olds 98
  180. 55 Olds Antenna Base
  181. Vin decode olds 54
  182. Oiling, or not oiling--ready to drive!
  183. What are these and where can I get 4?
  184. '53 Super 88 Trunk Light
  185. OE Radios and 4/8 Ohm speakers...school me
  186. I just can't stop! 55 Olds TreadleVac
  187. Olds Tow Truck ?
  188. 55 Olds Sedan (thanks)
  189. New Oldsmobile Gas Tanks will be fabricated!
  190. Olds 1903 extracted from Spartan Stadium
  191. 1930's Oldsmobile Hot Rod
  192. 1936 olds
  193. progress
  194. Rear ends and gears...
  195. rocketfest
  196. 1958 Old doors- different
  197. Dual or Triple Intakes
  198. Vintage cooler for the 50
  199. vapor lock ?
  200. does anyone know what this ground wire is for
  201. The 53 is finally registered
  202. headlight buckets
  203. color combo
  204. Got a few things done on the 53 over the weekend
  205. 1954 Oldsmobile Front Bumper
  206. 1970 Rallye 350 For Sale
  207. Finally a six-pack for the 50
  208. 1904 Olds "Old Scout"
  209. 1957 98 Convertible Rear Window Switches?
  210. A few pics of road trip, Pebble Beach and south
  211. Firing order drawings
  212. windshield 55 Olds for sale
  213. 1954 88 radiator
  214. Heater control valve removal
  215. shake down(and i mean shake)
  216. Road trip starts today
  217. Racin' Woodie
  218. 1940 Series 60 here
  219. Windshield didn't pass inspection update
  220. its not what i thought it was
  221. Chrome?
  222. my 49
  223. horn button
  224. Head gasket
  225. power steer hose
  226. interesting items found
  227. oil filter
  228. Road trip
  229. some OLD PARTS
  230. bumpers
  231. electric wiper motor installed today on the 55
  232. Heater blower missing - 1953
  233. front seat mounting brackets?
  234. 61 Dynamic 88 Fiesta Wagon - Grounded?
  235. 1955 Olds 98 brakes
  236. Will 98 taillights fit a Super 88?
  237. Our 53 finally here
  238. No VIN Plate - '51 88
  239. Gear Ratios for 56 Hydramatic?
  240. 56 olds dash vents measurements
  241. Shop Manual 1950-51 Oldsmobile in hand
  242. A little help on a source for a clear windshield for my 55
  243. 55-56 driveshafts, 88 with auto
  244. Hood replacement update
  245. 324 engine rebuild opinions
  246. on the road
  247. Generator rebuild question
  248. 49 Old's 88 2dr club sdn, rebuild
  249. 1952 88 rear bumper same as 1953?
  250. 1957 Olds 88
