Body Sheet Metal Tape
Old Jan 2, 2014 | 03:14 PM
Olds Scott's Avatar
Where can I find a reasonable substitute for the tape that goes between the inner and outer fender and other sheet metal on a 55 Olds?
Old Jan 2, 2014 | 06:46 PM
m371961's Avatar
beaded fender welting?
http://www.steelerubber.com/fender-w...ead-70-1098-44
Old Jan 3, 2014 | 09:23 AM
Olds Scott's Avatar
No, it is a flat woven cloth tape that is used between sheet metal parts when they are bolted together.
Old Jan 3, 2014 | 11:30 AM
m371961's Avatar
Somebody here knows.
Old Jan 3, 2014 | 02:49 PM
Hairy Olds's Avatar
Shoveling Snow
Can you post or email me a pic of what your looking for.
I just talked to a 55 expert and he has paper product that goes in-between some of the front end sheet metal.
Old Jan 4, 2014 | 10:09 AM
DFitz's Avatar
74 2.8L Capri
I'm going to need some as well. Source?
Old Jan 4, 2014 | 11:31 AM
RonFX's Avatar
Body cloth
Hello:
We are doing a resto on a 1928 Model A, alot of the body joint stuff is close to what you are looking for, you might try Snyders Model A parts in NE Ohio.
Thanks Ron
Old Jan 5, 2014 | 08:28 AM
Eddiejr's Avatar
fender tape
I found it at local VolksWagon store
Old Jan 5, 2014 | 08:31 AM
Olds Scott's Avatar
Thanks guys, between the two I will check into them.
Old Nov 22, 2015 | 07:29 PM
Olds Scott's Avatar
Has anyone found a direct source for this product?
Old Nov 23, 2015 | 04:15 AM
RonFX's Avatar
Hello:
See above posts 7&8, the Model A cloth band is approx 2" wide for frame welt and 1" for around area hood rests on firewall. It is treated w/ an asphalt type material as well.
Thanks, Ron
Old Nov 23, 2015 | 09:26 AM
jozw30's Avatar
Strange that nobody makes/sells this for restorations of these cars specifically.
I was just going to put my car together without it......
Old Nov 23, 2015 | 05:37 PM
Olds Scott's Avatar
I wouldn't be surprised if this item was used on Cadillac, Buick, and Pontiac cars.
Old Nov 24, 2015 | 03:24 PM
DFitz's Avatar
74 2.8L Capri
I found some sheet gasket material that is very close, and probably a bit sturdier than the original body tape. I'll cut it in strips and use that. Cheap and easy. If it's just for squeak reduction, the gasket material should do the same job.
It should also work well for the circular rubber washers on the fender attach bolts.
Old Nov 27, 2015 | 06:18 AM
jkcab95's Avatar
If you had a '55 - '57 Chevy they make a complete die cut set of anti squeak gaskets. I can't seem to find any material that is similar to the original. 3M sells anti squeak tape that is made from UHMW and is very expensive. I think it is more for interior plastic parts then sheet metal panels. There is another company that sells polyester felt for the same purpose.
My biggest concern is that whatever material I end up with will not absorb water. I am afraid of creating a rust area where panels bolt together. I was debating over undercoating or not. I figured if I decided to undercoat I would do it while it is still dissembled and then the seam areas would be coated with rubber. I was thinking there would then be no need to add the anti squeak gasket?
Jeff K.
Old Nov 27, 2015 | 06:33 AM
jozw30's Avatar
Would love to hear from some folks that have recently restored one of these cars. What did you do/use?
Anyone?
Old Nov 27, 2015 | 08:47 AM
Tedd Thompson's Avatar
I used thick black gasket material also, so far no problems. It's doubtful any manufacture would make a pre drilled kit for Oldsmobile only but the tape thing sounds like it would be easy to use... Tedd
hilbily
Body work
Sep 9, 2014 08:54 PM
79 olds
Apr 4, 2014 08:12 AM
Professur
Body work
Dec 19, 2013 07:01 AM
Jody Karls
Jul 21, 2008 11:45 AM
tmbrennan
Jul 19, 2008 09:29 AM
