Riveting Discussion...'55 Olds and more
Old Sep 26, 2012 | 08:43 PM
Olds Dad's Avatar
Collector of Stray 55's
School me on rivets.
I bought replacement vent window latches from Danchuck (chevy guys) as they're the same for the Olds.
They come with replacement rivets for where they mount in the vent window frames.
Similarly, I bought the 'replacement rivets' for the wiper arms - the lower arm (base) where it mounts to the wiper transmissions is chrome - the upper "arm" is aluminum. I want to disassemble to have the mounts rechromed and then reassemble with the new rivets.
What tool do I use for these tasks? This is not "pop rivet" stuff.
I'm picturing an anvil with a 'recieving end' for the rivet shank that you peen over with a hammer, or a vice grip type deal...any input is appreciated as always.
Old Sep 27, 2012 | 06:46 AM
Russ P in MD's Avatar
Here are some rivet tools on McMaster's site. If you have a lathe you could probably make that tubular rivet tool yourself. But I've no idea what type rivet you are using. Otherwise I'd first look for used on eBay if you can't come up with a solution yourself. Do a test run before the actual installation.
http://www.mcmaster.com/#rivet-insta...-tools/=jh2l71
Old Sep 27, 2012 | 07:58 AM
There are different tools for different rivets. The 2 posted above for solid and tubular are probably one of whick you need.
69ishHoliday
Suspension & Handling
15
Jan 22, 2014 02:24 PM
kevin.horton
Jul 13, 2013 10:58 AM
oldcutlass
Non-Olds Engines
23
Oct 16, 2011 07:16 PM
Nor Cal Andy
Non-Olds Engines
33
Mar 8, 2011 02:41 AM
