Assembly Line Stampings
Old Sep 7, 2012 | 06:57 AM
Olds Dad's Avatar
Collector of Stray 55's
Anyone here successfully reproduced the stampings used on assembly lines? After degreasing my blower motor housing for my '55 I found this "23" stamp - there are also a few others on the car, an "OK" on the firewall, and other similar things.
Someone must make these rubber stamps - I have to guess that most GM used similar ones.
Anyone have a source?
Old Sep 7, 2012 | 07:07 AM
RALLYE KID's Avatar
I went to a craft store and made my own stamps.
Old Sep 7, 2012 | 08:39 AM
Russ P in MD's Avatar
You can easily find them for 60s era cars, I've not seen much if any for 50s, even Chevy. Unless you're doing a concours level resto it may not be worth the cost of having a stamp made. If you can get something close, inexpensive and "off the shelf" then it may be do-able. I have seen where guys will buy inspection stamps to use once, then resell on eBay etc.
Old Sep 7, 2012 | 12:07 PM
Olds Dad's Avatar
not necessarily doing a concours resto, but I do like details - and since I readily see it, I'd like to reproduce it if the cost wasn't too much...don't always get to disassemble a 57 year old car that was only 7 years old when it was 'put away'.
Old Sep 7, 2012 | 01:43 PM
stevengerard's Avatar
In line tube sells a bunch of those stamps but as others mentioned you can get those at office supply places and on line as well
Old Sep 7, 2012 | 06:57 PM
oldolds88's Avatar
when i worked at fisher body in the 70s and 80s we used a lot of railroad chalk,and lumber marking crayons to write on the fire wall,doors ect. just to show that it was inspected. sometimes the markings were to show a repair was needed and the writing was not covered up.
Old Sep 9, 2012 | 09:30 AM
tomsw31's Avatar
Take pictures and measure the physical dimensions of the stamping. Take them to an office supply company (Sta####) They can make a stamp for about $20 per stamp.
Old Sep 10, 2012 | 05:10 AM
Olds Dad's Avatar
thanks for all the input...I'll try the office supply route first I think
Old Sep 10, 2012 | 08:17 AM
If you just need numerals it will probably be cheaper to find them already made. Check eBay also. Not exactly the same, but have you considered stenciling with a paint marker if you can't find stamps or they are too costly?
Old Sep 28, 2012 | 09:47 AM
Lady72nRob71's Avatar
This might be helpful for those who want to make their own custom stamps.
http://www.michaels.com/Craft-Foam-S...cards&start=32
I ran across this looking for something else...
Allan R
Jan 18, 2026 11:04 AM
BlackGold
Mar 20, 2015 07:02 PM
101471X
Apr 22, 2013 07:40 PM
jcosta77
Jul 13, 2012 07:47 PM
scrappie
Apr 11, 2009 05:43 AM
