55 Olds PCV conversion
Old Nov 7, 2013 | 02:57 PM
Olds Scott's Avatar
I am ditching the road draft tube for a PCV valve. I am making a aluminum plate to bolt up to the crankcase baffle but need to know what valve to buy for the 324 engine with stock 4 barrel. Also can I run a T-fitting off the back of the carburetor for the valve and power brakes or do I need a separate carb base plate for the PCV valve?
Old Nov 7, 2013 | 03:32 PM
Tedd Thompson's Avatar
When I tried that there wasn't enough vacuum to supply the brakes that is if you are using the large vacuum port at the back of the carb .The treadle-vac is a little weird about low vacuum. Does your road draft tube smell or smoke If not the old system will work well as it was built....Tedd
Old Nov 7, 2013 | 06:00 PM
Olds Scott's Avatar
Thanks for the information Tedd, I want to run the treadle-vac and did not consider that problem. I guess an additional base plate with vacuum port would still affect the Treadle-Vac system.
Old Nov 8, 2013 | 07:54 AM
Ya, I thought it was a good idea until I tried the brakes, wasted a couple hours making everything fit then had to put it all back as original. but I have had no problems with it since mostly because my engine is fresh with a new rebuild. I have seen worn 394's that would smog you out at a stop light they smoked so much......Tedd
65Delta
Sep 9, 2014 03:24 AM
oldrelics
Jul 28, 2014 03:28 PM
the_duke
Apr 30, 2011 11:14 PM
dman0712
Oct 28, 2010 10:53 AM
sborruso
Aug 24, 2009 07:13 PM
