1954 Differential Gear Oil
Old Dec 21, 2013 | 06:58 AM
monaco's Avatar
Hi,
which kinds of rear axle oil do you use on your 1954 differential?
The recommended Lubricant is a SAE 90 Multi Purpose Hypoid Lubricant, till -10°F and SAE 80 below -10°F
Question:
Would you recommend/use a 80W 90 Gear Oil (API Service, GL-3, GL-4, GL-5) instead?
like this one:
http://www.autozone.com/autozone/acc...er=692277_0_0_
I'm just asking because I have this oli at home and the SAE 90 Multi- Purpose-Hypoid Lubricant is pretty hard to get here.
Thank you and Merrx X-Mas,
Monaco
Old Dec 21, 2013 | 07:04 AM
Yes, absolutely. That is the improved successor to the recommended oil.
If it had been around in 1954, they would have recommended it then.
Old Dec 21, 2013 | 07:13 AM
monaco's Avatar
Good to know.
Thanks Eric!!
White_Knuckles
Mar 23, 2014 10:38 AM
cutlassclay
Drivetrain/Differentials
Feb 18, 2014 08:56 AM
68oldsguy
Apr 20, 2013 01:38 PM
randomarrival
Jul 13, 2012 05:52 PM
