Front oil "piss" plug
Old Aug 22, 2013 | 06:34 PM
Olds Scott's Avatar
Front oil "****" plug
About to reinstall the timing chain oiler plug I notice the threads are buggered up from the factory. Having problems finding a replacement, have heard a Chevy plug can be used and a 1/16" hole drilled. Would rather use a genuine Olds part. Anyone got a extra one floating around that I could use?
Old Aug 22, 2013 | 06:38 PM
Octania's Avatar
Sure
RH plug only
What part is buggered?
Old Aug 22, 2013 | 06:50 PM
Olds Scott's Avatar
Threads on the plug itself were messed up, did not notice until after the plug was cleaned. Engine has never been rebuilt so the only thing I can figure out is that it was installed incorrectly at the factory.
Old Aug 25, 2013 | 08:34 AM
Octania's Avatar
What year?
I have no parts for the car pictured... but know folks that do.
can you just file or grind away the malformed part of your plug? You don't really need 100% of the threads to do its job....
Old Aug 25, 2013 | 09:00 AM
Olds Scott's Avatar
Thanks Octania, finally sucked it up fixed the threads on the plug. Damage was not consistant on the threads so with some careful filing was able to restore plug and have installed in block.
ds00469
Jan 25, 2014 05:12 PM
gearheads78
Jun 15, 2012 07:53 PM
chasman414
May 21, 2012 10:58 AM
