3/8" rear oil galley plug
Old May 19, 2012 | 03:15 PM
chasman414's Avatar
My names Charlie and this is my 1st post and I have a question.
I have a 1970 442 with a 455ci ols engine which I am currently rebuilding.
I notice in my shop manual there is supposed to be a 3/8" pipe plug behind the 29/32 freeze plug on the left rear of the block near the cam plug.
PP-40 Oil Galley Pipe Plug
A 3/8" pipe plug with a .040 oil hole in it to replace the stock left rear oil galley plug. If your oil galley plug does not have a .040 hole in it, you may experience excessive distributor gear and camshaft distributor gear wear. This plug is located behind the 29/32" freeze plug on the left rear side of the camshaft plug in the bell housing area. If left out, you could experience
a serious drop in oil pressure.
Mine does not have this or any way to install it, when you look at my block inside I can see the inside of the freeze plug thats it?
Old May 19, 2012 | 04:26 PM
Do you mean the pipe thread plug behind this freeze plug?
Old May 19, 2012 | 04:36 PM
BILL DEMMER's Avatar
Just the facts...
you will have to remove that "freeze plug" to view the pipe plug in question. you may need to squirt some cleaner in there, as the .040" hole in the plug is usually plugged with engine smegma after a bunch of miles. it can be either an inside hex(allen) or inside square drive plug. if it's square, it should be 5/16".
bill
Old May 20, 2012 | 06:09 AM
chasman414's Avatar
Old May 20, 2012 | 06:39 AM
chasman414's Avatar
Yes, and when I roll the block over all you see is the inside of the freeze plug.I was going to attach a photo but I guess I don't know how!
Old May 20, 2012 | 08:25 AM
Is the engine apart?
If so, then run a bottle brush (or a dowel, or anything) through the LH gallery, from the front pipe-thread plug behind the timing cover, to the back.
Look into the distributor hole.
If the brush comes out and you can see it, then you're right, there's no plug.
Old May 20, 2012 | 10:28 AM
chasman414's Avatar
Old May 20, 2012 | 10:29 AM
chasman414's Avatar
Got it, no hole in it though ! Thanks a million.
Chas
chasman414's Avatar
bill
Old May 20, 2012 | 10:30 AM
chasman414's Avatar
Got it. Thanks.
Chas
Old May 21, 2012 | 10:58 AM
Just the facts...
good deal.
bill
simonb.
Apr 5, 2020 02:29 PM
ds00469
Jan 25, 2014 05:12 PM
Sean Blake
Dec 3, 2013 09:59 AM
knighthawk
Feb 14, 2011 03:28 PM
