Power windows 56 Olds 98
Old Mar 4, 2013 | 08:50 AM
citcapp's Avatar
I am helping guy fixing a couple of electrical items on his 56 Olds 98 and I am having trouble finding a couple of parts.
1. Need the power window relay. I checked Fusick and two other sources and they only stock one relay for both the windows. It is a three connection relay. The one they show is has three connections points and N/O and N/C contacts with the magnetic coil grounded to the case. The one I pulled from the 56 has four connections points and N/O and N/C contacts with the ground isolated from the case. It appears to be original but I cannot find any part numbers on the case
Any one know where I can find the correct relay.
I am also looking for a 6-way seat relay for a 57 Olds seat that is installed in the same car
Thanks in advance
Pat
Old Mar 4, 2013 | 09:42 AM
59-59-59's Avatar
If your looking for this relay, it looks to be a three connection one. They got one on that big auction site -NOS Delco- and 30 bucks cheaper than Fusick. I would give you the link but don't know how.
Old Mar 4, 2013 | 02:18 PM
citcapp's Avatar
Yes I have also seen the 3-connection relay. This 56 has a four connection relay and all four connections are in use.
Next question does anyone have the wiring diagram for the power windows it is not in the 1956 Oldsmobile shop manual so it must be a separate bulletin. With the wiring diagram I should be able to figure out a solution.
I have searched the internet for the diagram with no success
thanks in advance
Old Mar 5, 2013 | 07:32 AM
okie88's Avatar
Old Mar 5, 2013 | 07:35 AM
okie88's Avatar
Pat, hopefully you can read that. It's for a 55, but they may be close.
Old Mar 5, 2013 | 08:26 AM
citcapp's Avatar
Thanks, I believe it is the same from 1954 to 1960 so this should work
Old Mar 9, 2013 | 07:42 AM
hialeah56's Avatar
1956 holiday coupe
Thanks in advance
Pat
hope this is the one you're refering to
my book shows two part numbers one without automatic 6 way seats and one with
w/o 1116895
w 5945189
see pic
Old Mar 9, 2013 | 07:46 AM
hialeah56's Avatar
1956 holiday coupe
btw the other relay you were looking for is also in the same pic just noticed
pn 4711553
Old Mar 9, 2013 | 07:55 AM
hialeah56's Avatar
1956 holiday coupe
1116895
http://www.ebay.com/itm/54-55-56-57-...d393a3&vxp=mtr
http://www.ebay.com/itm/Nos-Delco-Re...c414b0&vxp=mtr
or 5945189
http://www.ebay.com/itm/1955-Cadilla...ab35f5&vxp=mtr
have not found 4711553 yet
BeenThere
Sep 28, 2014 06:04 AM
BeenThere
May 23, 2014 07:47 AM
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
rustycarr
Mar 7, 2007 06:24 AM
