Flywheel tool
Old Sep 1, 2013 | 03:39 PM
Olds Scott's Avatar
Flywheel tool
What is the best way to hold the flywheel from turning when installing the harmonic balancer on my 324 engine when on an engine stand?
svnt442's Avatar
Something like this:
Old Sep 1, 2013 | 03:50 PM
Olds Scott's Avatar
Was thinking of some sort of flywheel tooth tool that would bolt to bellhousing some way. Kent Moore mad a lot of these tools but which one for a 324?
Old Sep 1, 2013 | 04:00 PM
Octania's Avatar
not familiar with the 324 much but I generally have used vice grips clamped onto a junker flexplate. Butt up against the stand
Old Sep 1, 2013 | 08:18 PM
Tedd Thompson's Avatar
I think we just stuck a small hooked crowbar(two feet long)between the flex plate and bellhousing catching a tooth. I don't remember it being a major problem....Tedd
Old Sep 1, 2013 | 08:23 PM
Or a long screw driver on the flex plate or torque converter bolts.
Old Sep 2, 2013 | 12:15 AM
rustyroger's Avatar
'87 Delta 88 Royale
An old valve heated and bent 90 degrees works just fine
Roger.
Old Sep 2, 2013 | 07:31 AM
wmachine's Avatar
Trying to remember member
How about the old school trick of taking out a spark plug and feeding some rope into the cylinder with the piston toward the bottom of the stroke. Obviously keep a fair amount out.
Old Sep 2, 2013 | 07:48 AM
Or use a impact wrench,I think thats how mine came off.....Tedd
Kaline
Apr 18, 2022 03:35 PM
scrappie
Feb 11, 2013 09:04 AM
Dan Wirth
Nov 12, 2009 10:38 PM
tim72
Drivetrain/Differentials
Apr 3, 2009 09:00 AM
jeffabarber
Aug 27, 2008 07:37 PM
