engine number
Old Nov 15, 2013 | 08:14 PM
oldsmoguy's Avatar
engine number
Is the engine number supposed to match the body number on a 51 S88?
Is there a place I can go to decode the engine number same car?
Old Nov 15, 2013 | 08:32 PM
jaunty75's Avatar
No, I don't think so. It wasn't until the late '60s that a VIN derivative was stamped on the engine. I think the engine number will tell you what engine it is, so you'll know if it's correct for that year, but there's no way to tell if the engine is the one that the car came with originally from the factory.
As far as decoding the number, I know of no website that will tell you. Just post the number here, and someone will know and answer.
Old Nov 15, 2013 | 08:57 PM
oldsmoguy's Avatar
engine number
OK The engine number is 8C191470
Old Nov 18, 2013 | 09:37 AM
Russ P in MD's Avatar
Actually if you have the original owner's manual it should have the engine number penned in by the selling dealer. At least they did in'55. Does not match the VIN, but you may be able to correlate if the estimated engine build date falls in line with the car build date. I believe the service manual has the breakdown on the engine code - probably year or use code/plant code/ and sequential order with in the range used for that model year.
Alg
Jan 1, 2013 05:04 PM
marcello
Ninety-Eight
Sep 5, 2008 05:20 AM
roadster-rob
Mar 9, 2008 10:24 PM
perro
May 2, 2007 02:39 PM
1BAD68"S"
Sep 17, 2006 06:49 AM
