- '47 olds 66
- Crankshaft pulley removal to change front motor mount on a 324
- treadle vac removal- how to
- 1950 76 vs. 88
- Identification of Vehicle Olds vs Chevy
- 49 coupe trunk brace/trunk extension
- 1950 floor replacements
- 1934 Oldsmobile 213 Flathead
- Help Identifying a Steering Wheel & Grill
- My '49 Olds 98 Convertible Getting Closer To Paint
- Parts to have in stock for '57
- 57 Olds 88 Differential ratio
- 1957 wagon
- TOWBAR for 59 olds
- Autronic Eye Bypassed
- '50 Olds, disc mod orig style wheels
- 54 olds super 88 Mystery noise and other mysteries
- disassemble 1957 wiper shitch
- Olds j2 rocket engine with 3 deuces
- What to expect of an SGS Vehicle Inspection in the UK?
- 1952 Olds 88 Doors/Trunk Key the Same?
- 40 Years in a Barn
- Valve stem seals
- 1959 Oldsmobile 98 Convertible - Interior Help :)
- Going through the laundry list. Bunch of stuff
- '57 Olds 371
- Raingear electric wipers in '56 Olds?
- Chevrolet A Arms on a '56
- Can I Feed the Blowby Back into the Engine
- 1948 Oldsmobile 98 club sedan
- 1962 394 HO rocker shaft dowel pins
- Everything I've said about fixing a 4gc is doubtful at this point
- !949 Olds 98 Fender Extension
- Where to find Engine # on 53 Fiesta
- Need Help '55 88 Rear Bumper
- Engine stand for a 371
- '56 Chevy wiring harness for '56 Olds?
- Ididit tilt column for '56?
- Oldsmobile 98 1953
- Engine Identification Number on 1950 Rocket 88
- Any 1950 88 Owners in UK? Petrol & Additive Ques.
- Need advise on engine removal
- 55 headliner stainless bows
- Power steering conversion 1940 Olds
- 1947 or 1948 classic oldsmobile convertible
- 1970 Olds 98 convertible right door mirror
- 1956 Oldsmobile's
- Rearend pumpkin 501826 j309
- 57 or 58 carb to bellcrank to transmission linkage
- 1950 Field Fresh Rocket 88 spotted at local swap meet
- Best plan to part out?
- 56 olds rocket
- 56 Fuel pump
- 55 olds help
- 1953 oldsmobile power brakes conversion
- Another engine question.
- Unidentified panel and missing panel
- instrument cluster
- Olds F36 Engine Compression
- Just dragged her out of a 20 year hibernation!
- 1957 371 engine questions.
- 1941 windscreen defroster fitting
- 57 Olds-Steering Coupling
- 1957 olds
- 1957 Holiday Coupe - Back Glass
- 1958 Olds 371, Intake, and Tranny
- '41 98 rocker panels
- 1957 breather tube
- HELP front seal dimensions
- 1955 Olds 88
- Pillar reinforcement for 55 88
- Frustrating same reoccurring electrical issues
- Need Fuel Tank for '36 Sedan
- Gas pedal removal
- 1956 Oil pressure
- 1956 Jetaway transmission issues.
- 55 Olds Hydramatic leak, what kind of fluid to use?
- 1936 4 door sedan fuel/vacuum pump and vapor lock issues
- 56 Olds power steering gear overhaul
- 55 Olds steering gear conversion
- 1957 olds headliner installation
- 1949 Olds 98 Steering Column
- 1956 new generator
- Fuel tank sending unit 58 Super 88 w/AC
- 1957 88 rear door glass
- 1951 Olds 303 ci Starter/Flywheel Issue
- Olds Brochure Info- 56 Deluxe Hub Caps
- headlight bezel
- 1957 Super 88 key codes
- unknown tag
- 1957 Super 88 door trim
- Converting 57 olds sedan to hardtop
- 1955 grille/bumper trim problems
- Help with trim code for 56 Starfire
- Scarebird 53-56 Drum Rim Disc Conv Kit
- no brake lights
- 1955 Olds hydramatic shift lever grommet
- Near Stranding!
- need 46 coupe assembly help
- Turn Signal Switch 1950 88
- 1952 instrument cluster removal
- Looking for info on my 50' body tag
- Check your wiper blades!
- 53 coil springs
- 50 Olds
- 1955 Olds brakes upgrade
- 72 oldsmobile 350 in a 1953 oldsmobile
- 1955 Super 88 Sedan Bumper
- engine bay paint color
- 56 98 PS Pump
- Need help with 1936 Olds trunk handle
- Pitted Piston
- New findings on the 4GC accelerator pump problem
- 1936 Oldsmobile Business Coupe
- 4GC Venturi Cluster 5142
- Choke Heat Tube
- Installing AC in a non-AC '55 88
- Best place to get schematic drawings
- Rocker Arm Plug
- 1955 Olds 455 engine swap
- 53 Vacuum advance & fuel lines painted?
- 1955 Olds bench seat lower plastic
- '56- Removing Heater Control Knob
- 1952 Olds 303 Fuel Pump Lines
- Alternator Used For 12 Volt Conversion ?
- Fitting Aftermarket Rad in 1952 Super 88
- Front Bench heigt '47 olds 66
- alignment tool castor camber kingpin
- my F-32 needs wheel trim rings
- Questions on a 56
- 1956 88 Fuel and Oil pump rebuild
- 1953 Grille Extension Wanted
- 53 valve covers
- 1955 Olds 4 barrel adjust with vaccum guage
- '49 Olds 88 choke heat tube?
- 6V to 12V
- 56 88 Speedo cluster lubrication?
- 4 way power bench seat mechanism
- 257 inline eight starter
- 1957 feista HT wagon doors
- 57-98 exterior visor install
- '49 88 valve covers
- 1955 trunk pan rust repair
- -40 Series 90 Custom Cruiser Club Coupe
- A 58 98
- 55 Hood Hinge rebuild
- Not 56 324?
- Hard start up after setting a few days (55 Olds)
- Hydramatic band adjust tools?
- Adjusting linkage
- 53 super 88 2 dr hardtop parts wanted.
- Lifting your car onto jack stands
- Hood ornament ID, please.
- 56 ground strap
- Looking at a 1956 Super 88
- 56 Olds throttle/jetaway linkage
- 1940 information
- 1937 Olds wont start
- 1956 Timing marks
- Distributor
- 4GC rebuilt - issues
- 57 Front shocks & stabilizer
- 1956 Rear Drums
- proform distributors
- Brake Lines 1954 88
- Tuning
- Olds 455 Engine Brackets for Street Rod
- Restored carb?
- engine work
- Are they the same '49 & '50?
- 56 Olds S88 conversion to power windows
- 55 olds paint
- 56 Olds AC Bracket
- 1950 Olds 88 split windshield
- 56 model O?
- 56 4bbl carb wanted
- C-pilar from a 55 four door to 2 door?
- 3rd member Gear ratio for 47 olds?
- 55 Hydramatic throttle valve lever problem
- Removing steering box on 1949, any tips?
- 1940 Olds Sedan wins best street rod award
- 53 Engine Rod Bearings
- 53 Valve Lapping
- 1957 J2 center carb jetting
- 1941 oldsmobile
- 53 spin on oil filter?
- Not mine, but unusual so I'm sharing. Built 303 & automatic on CL
- 56 Interior paint
- Rubber from 1940s - What Is Available?
- 1949 olds fuel guage
- grazes and backfiring
- 55 Hood
- 56 heads
- Clanking noise when driving when cold
- 371 rebuild ----PISTONS
- 56 headlight
- Treadle Vac pics and questions
- 53 running badly.
- 1948 Oldsmobile fuel gauge
- 55 Olds outside mirrors
- 1955 olds engine rebuild snag
- 53 Thermostat?
- Pertronix for 56
- Cooling system
- 55 molding clips
- Tool J-720 ???
- 56 License plate brackets
- how wide rims for a 56
- New hubcaps
- '55 transmission to engine gasket
- Home on the hook
- My first drive in the 53
- 56 Fuel sending unit
- 56 Gas tank
- 56 98 Is this normal?
- 56 holiday power window relay
- 55 Olds front splash apron
- 1956 98
- pertronix question
- Brake pedal free play
- 47 Olds windshield division bar and reveal moldings for windshield
- 1955 cowl vent drains
- 1956 Olds 88 Speedometer Removal
- order of restore
- 53 Timing Chain
- 55 Olds windshield washers
- my 1955 hardtop
- 1955 Olds
- 56 Spring removal
- 53 Wont Start!!
- 57 Olds power brake booster vacum
- 1953 Olds Super 88 I need some advice regarding the Power Brake rebuild
- 1957 Fuel Filter location
- need help finding bracket
- Meet "Maggie"
- Where to get carpeting?
- Sold my '55
- headlight switch
- 53 4dr 98 Sill Plates
- 53 Head Liner.
- 1958 Fiesta Station Wagon - help needed with vacuum system - wipers and heating
- right color?
- 1928 Emblem, Need Help with ID
- 53 Front Seal
- thermostat
- 52-53 Fender Skirts update
- what wheels
- Dearborn MI car sale this weekend
- 1954 98 olds PS
- 1934 parts
