Rearend pumpkin 501826 j309
Old Sep 22, 2017 | 09:17 PM
Thirty2ragtop's Avatar
I'm a newbie. Any help would be greatly appreciated. I have had a 1932 Ford 3 Window coupe dragster in my garage (in storage) since 2001. Well, at 69 years old, it's time to get to the restoration. Before I received it, a young guy back in 65....(he's my age now!).....put this rear end in the car with a 50 olds engine through a 39 Ford box. I'm trying to identify all of the pieces now and the rear end is stumping me. Any help out there in Olds land? Thank you all.
Old Sep 22, 2017 | 09:46 PM
stevengerard's Avatar
does this link help at all
http://www.hotrod.com/articles/1303s...bile-rearends/
Old Sep 25, 2017 | 08:02 AM
47 Convertible's Avatar
Need photos of rear end from backside, sides, and of any numbers cast or stamped on exterior. You may have to get out the wire brush to bring out the numbers/letters. Since the original builder put in a 50 Olds engine he may have gotten the rear end out of the same car. Its not uncommon for a builder to buy a "donor" car and use several parts from it. With that info there are a number of members who know Olds stuff from A to Z who can help you identify it.
Jerry
Old Sep 26, 2017 | 06:15 PM
Tedd Thompson's Avatar
I read somewhere in a post that this was a 324 engine, not a 50 Olds which would be a 303 CI or did you mean 50's era Oldsmobile? If you give us the number on the heads, if it has numbers. No number is 49-51 #2 is 52 -53 #7- 54 #8- 55 #10= 56 we might narrow it down a little. This is off my head but I think it is correct. If this has been discussed before and I missed it please disregard this comet.... Tedd
Old Sep 28, 2017 | 09:57 AM
TRWham's Avatar
My parts book shows a 501828 for '39 to '52 (except certain ratios). That J309 could be a date code for October 30, 1949 if the codes then were consistent with later ones for GM rear ends. CFD (Central Foundry Division) date codes for Olds engine blocks are straight Julian, but I'm not sure about casting date codes for other components.
JCMC64
Drivetrain/Differentials
Jan 21, 2013 10:23 PM
J-(Chicago)
Oct 11, 2009 05:11 PM
1BAD68"S"
Dec 29, 2007 09:05 PM
66JET
Jan 6, 2007 02:33 PM
