Need Pics of inside pumpkin 71-72' 8.5 10 bolt
Old Jan 16, 2013 | 07:44 PM
JCMC64's Avatar
JC
Can someone please post some good pics of a empty 8.5 pumpkin, inside the pumpkin overall and especially where the axle gears mount to on both sides and into the tubes. Tons of photos out there with carrier installed, but little to nothing of empty pumpkin. Need to know if below is a problem or not. Thx in advance.
Old Jan 17, 2013 | 10:05 AM
JCMC64's Avatar
JC
Ok...no pics. Can someone tell me if above is a problem or not? Thx.
Old Jan 17, 2013 | 04:08 PM
RetroRanger's Avatar
72 Olds CS
I dont know but heres a bump
Old Jan 17, 2013 | 09:01 PM
JCMC64's Avatar
JC
Thx ranger...guys, some advice please? Thx.
Old Jan 17, 2013 | 09:07 PM
oldzy's Avatar
This is all I have of mine unfortunately.
Old Jan 18, 2013 | 12:01 AM
JCMC64's Avatar
JC
Ah! Great pics but the caps are on...grrr. thx for posting though.
Old Jan 21, 2013 | 10:01 PM
monzaz's Avatar
rear end info
It is fine. That is so the oil can bye pass the carrier bearing to the axle bearing to get oils. You are ok that is a factory cast in notch. JIm
The picture with the caps is a OLDS 10 bolt 8.5 and has the holes in the case out board the carrier bearings that is hoe the axle bearings get their oil.
It is the whole reason for the BIG eye brown on the chevy covers the oil gets caught on that trough and trickles into the holes outside the carrier bearings and into the axle tube.
Take care, Jim Mitschke
J D
Old Jan 21, 2013 | 10:23 PM
JCMC64's Avatar
JC
Alright !! Thx Jimbo! I thought it might be that, but what threw me is the other sides hole (Driver side) is much smaller. So I thought it odd there would be 2 different size
holes on each side fo oil seepage. Passenger side is about an inch. Driver side is about 1\4 inch or so. How does the oil feed back into pumpkin or does it?
Jim, can you also take a look at that pinion spline thread I started last week that is right near the top? Pinion gear has flat tipped splines for lack of better terminology. Its a set of barely used Older Richmond 8.5 3.42 gears I got real cheap. Pinion splines are flat tipped, my original pinion yoke are peaked tipped splines. No workie.
looks like I need a new pinion yoke, or what?
Anubis
Oct 31, 2013 11:13 AM
BIGJERR
Jan 22, 2011 05:26 PM
nuttkaze
Jun 4, 2010 06:53 AM
Supreme68
Mar 22, 2010 06:54 AM
J-(Chicago)
Oct 11, 2009 05:11 PM
