Raingear electric wipers in '56 Olds?
Old Nov 29, 2017 | 07:05 PM
michaelkellett's Avatar
I swear I read in one of the threads here that someone installed RainGear electric wipers in their tri-five Olds and now I can't find it anywhere... Has anyone successfully installed RainGear in their (in my case, '56) Olds? I'm curious if the '56 Chevy system will fit properly as the two cars are dimensionally similar.
Old Nov 29, 2017 | 08:52 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I was not familiar with RainGear and just looked at their site. Man those things are expensive. I put electric wipers on my 54 and they were like $215 and made to fit. They are bolt in and work perfectly. I can find the name if you are interested.
Old Nov 30, 2017 | 02:44 AM
ignachuck's Avatar
Frank Ignachuck
The most popular is New Port Engineering:
https://newportwipers.com/
As Glenn said, easy to install and work perfectly. And if you do it right, you can use the original control **** on the dash.
Old Nov 30, 2017 | 08:15 AM
Tedd Thompson's Avatar
X2 on the Newport, work great and look stock if you are a chevy man or judge.
A 57 chevy electric motor can be made to work on a Old's but new holes will need to be drilled and to me it's more work than just putting a Newport in and and just get on with life. Here is a link on the Newport that might help you on your install if you go that way others have found it helpful....Tedd
https://classicoldsmobile.com/forums...oday-55-a.html
Rocketowner
Apr 4, 2015 05:53 AM
d.smith1
Jan 30, 2008 12:08 PM
atownhockey19
Bravada
Dec 19, 2006 12:37 PM
nohn
Nov 30, 2006 02:35 AM
bbock
Jun 5, 2006 11:50 AM
