windsheild wipers have a mind of there own
Old Sep 23, 2006 | 09:31 PM
atownhockey19's Avatar
so bacically they dont turn off when there suppose to...they turn on right...but they keep going for atleast 10-15 seconds after i turn them off...and they decide to turn off all the way up or half way up the window...
Old Sep 24, 2006 | 04:55 AM
ozoneblue's Avatar
Cool W S wipers
Try tighting the mounting bolts if that dosent work add a extra ground wire to the metal part of motor this is quite common
Old Sep 24, 2006 | 12:29 PM
i also read something about a cracked circut board or something i cant quite remember....either that or a lose soder joint...i will try your suggestion first rather than spend 50$ on the new circut board
Old Oct 21, 2006 | 02:02 PM
cliffg8's Avatar
Had that problem with mine. Found that the solder joints connecting the wire plug to the circuit board on the wiper motor were loose. Resoldering the joints fixd my problem.
Old Dec 19, 2006 | 12:37 PM
can you post up on how to do this???
like about where everything is...
Bernhard
Jun 8, 2014 05:29 AM
ToroToro
Feb 2, 2011 06:22 PM
70 cutlass s
Dec 22, 2009 10:22 AM
IDAS 69
Sep 7, 2009 04:54 PM
MN71W30
Feb 22, 2009 11:09 AM
